TLineSeries Marks Arrows go through callout.
ChuckHutchings
Post by ChuckHutchings » Thu May 02, 2013 5:39 pm
If the callout is below the line series and the callout is transparent, the arrow is drawn up through the box/text to the line. Is there a property I'm missing to have the arrow originate at the top of the callout box?
(I'm using version 7.06. Yes. I know. It's a long story.)
Chuck
Re: TLineSeries Marks Arrows go through callout.
Post by Yeray » Fri May 03, 2013 3:05 pm
Hi Chuck,
I understand you have something like this, isn't it?
uses Series;
  Chart1.View3D:=false;
  with Chart1.AddSeries(TPointSeries) do
    FillSampleValues(10);
    Marks.Visible:=true;
    Marks.Callout.Length:=-50;
    Marks.Arrow.Color:=clRed;
    Marks.Transparent:=true;
In that case, what you could do is to manually set the marks ArrowTo.Y positions as in the following example:
var i: Integer;
    tmpPos: TseriesMarkPosition;
  Chart1.Draw;
  with Chart1[0] as TPointSeries do
    for i:=0 to Count-1 do
      tmpPos:=Marks.Positions.Position[i];
      tmpPos.Custom:=true;
      tmpPos.ArrowTo.Y:=tmpPos.LeftTop.Y;
ChuckHutchings
Post by ChuckHutchings » Fri May 03, 2013 4:46 pm
Yep. That's what I was looking for.
Chuck
ChuckHutchings
Post by ChuckHutchings » Tue May 14, 2013 7:16 pm
They decided to leave the labels opaque so I never verified the above fix. Now I have to do it for another reason and it's not working - I'm getting an exception.
In the onGetMarkText event I'm setting the arrow length and if I detect it's going below the line I have:
tmpPos := Sender.Marks.Positions.Position[ ValueIndex ];
tmpPos.Custom := True;
tmpPosArrowTo.Y := tmpPos.LeftTop.Y;
Unfortunately, tmpPos is nil.
(Note that I'm using a TLineSeries, not a TPointSeries.)
ChuckHutchings
Post by ChuckHutchings » Wed May 15, 2013 4:47 pm
Well, I figured out that the Positions haven't been created when onGetMarkText is called so I've moved the logic into the AfterDrawValues procedure. The code is executing without error and seems to be doing what I want but the arrow is still going to the bottom of the label.
ChuckHutchings
Post by ChuckHutchings » Wed May 15, 2013 7:17 pm
I copy/pasted your example code into my project and it doesn't work either. Is this maybe a bug in my version of TeeChart?
Post by Yeray » Thu May 16, 2013 4:13 pm
What about this? I've made it with TeeChart v7 and Delphi 7.
  private
    { Private declarations }
    procedure CalcMarks;
uses Series;
  CalcMarks;
procedure TForm1.CalcMarks;
var i: Integer;
  Chart1.Draw;
      tmpPos.ArrowFrom.X:=GetHorizAxis.CalcPosValue(XValues[i]);
      tmpPos.ArrowFrom.Y:=GetVertAxis.CalcPosValue(YValues[i]);
      tmpPos.ArrowTo.X:=tmpPos.ArrowFrom.X;
      tmpPos.ArrowTo.Y:=tmpPos.ArrowFrom.Y-Marks.Callout.Length-tmpPos.Height;
      tmpPos.LeftTop.X:=tmpPos.ArrowFrom.X-(tmpPos.Width div 2);
      tmpPos.LeftTop.Y:=tmpPos.ArrowTo.Y;
  CalcMarks;
  CalcMarks;
  CalcMarks;
ChuckHutchings
Post by ChuckHutchings » Thu May 16, 2013 6:03 pm
Thanks, I finally figured it out - I had to make a final call to Chart.Draw after setting the Y value.
