Problems with linear Gauge
Friis
Post by Friis » Sun Apr 14, 2013 8:12 pm
I have a linear gauge (see attachment Gauge.jpg). I would like to change the brush of the hand like this
Hand.Brush.Style := BsHorizontal;
so that the hand will have horizontal lines similar to the attached sketch "sketch.jpg"
However, setting brushstyle to BsHorizontal does to seem to work - what am I doing wrong?
This is the entire code:
Chart3.Title.Visible := false;
chart3.LeftAxis.LabelsFont.Size := 22;
chart3.LeftAxiS.Increment := 0.25;
chart3.LeftAxis.AxisValuesFormat := '#0.00';
chart3.FreeAllSeries();
chart3.RemoveAllSeries;
with Chart3.AddSeries(TLinearGauge.Create(self)) as TLinearGauge do
    Horizontal := false;
    RedLine.Visible := false;
    GreenLine.StartValue := -0.5;
    GreenLine.EndValue := 1.5;
    GreenLine.Gradient.Visible := true;
    GreenLine.Gradient.StartColor := cllime;
    GreenLine.Gradient.EndColor := cllime;
    GreenLine.Color := cllime;
    GreenLine.VertSize := 20;
    Minimum := -1.0;
    Maximum  := 2;
    Axis.Increment := 0.25;
    ValueFormat := '#0.00';
    Hand.Brush.Color := clBlue;
    Hand.Brush.BackColor := clred;
    Hand.Transparency := 20;
    Hand.Emboss.Visible := false;
    Hand.Pen.Color := clNone;
    Hand.Gradient.Visible := true;
    Ticks.VertSize := 100;
    Ticks.Visible := false;
    Face.Color := clwhite;
    Face.RoundSize := 0;
    Face.Gradient.Visible := false;
    Frame.InnerBrush.BackColor := clBlack;
    Frame.MiddleBrush.BackColor := clGray;
    Frame.OuterBrush.BackColor := clBlack;
Re: Problems with linear Gauge
Post by Yeray » Wed Apr 17, 2013 1:45 pm
Hi Hans,
Right, the pattern colors are difficult to control. A revision of the Patterns is already present in the wish list as an enhancement for future releases (TV52016522).
I've found what could be a fix for the issue you've reported. It would allow you to draw the blue&transparent pattern in the LinearGauge Hand. However, possible collateral damages are being studied.
