Recompile error
dpatch
Recompile error
Post by dpatch » Fri Mar 15, 2013 12:05 pm
I'm trying to run the recompile program to build XE3 32 and 64 bit. When I do I get the following error...
Why is it looking in TeeChart Pro 8.08 Full Source Code..... directory? Do I need to install version 8.08 code first?
TeeChart Pro
Compilation started: 3/15/2013 7:58:00 AM
RAD XE3.Win32 v17 (RAD XE v10 Professional)
EXCEPTION:
Cannot copy file: D:\Program Files (x86)\Steema Software\TeeChart Pro 8.08 Full Source Code\Sources\FMXTee.Chart3D.pas to D:\Program Files (x86)\Steema Software\TeeChart Pro 8.08 Full Source Code\Sources\FMX\FMXTee.Chart3D.pas
Error Code: 2 Description: The system cannot find the file specified
Re: Recompile error
Post by Sandra » Fri Mar 15, 2013 3:26 pm
Hello dpatch,
I am afraid that TeeChart Pro 8.08 isn't supported by RAD XE3, RADXE2 and RADXE as you can check in next threads:
http://www.teechart.net/support/viewtop ... 83&p=57283
http://www.teechart.net/support/viewtop ... 147#p52147
http://www.teechart.net/support/viewtop ... 615#p49573
Moreover, If you are interesting you can do something as do the client in this link with version 7. But if you want work with XE3 without problems, I recommend you upgrade to the actual version.
dpatch
Re: Recompile error
Post by dpatch » Fri Mar 15, 2013 5:22 pm
Please read my initial post carefully before you respond as our time zones are very different and I will have to wait another full day.
I did upgrade to Tee Chart v2012.07.121105 and I installed the binaries but they do not include 64 bit so I am trying to recompile the source code. I am running the recompile application that shipped with TeeChart2012SourceCode.exe and that application is what is looking for version 8.08 code when I select only the XE3 32 and 64 bit checkboxes. The error is real since I DO NOT install Tee Chart version 8.08 source code.
Why is it looking for version 8.08 code?
Re: Recompile error
Post by Sandra » Mon Mar 18, 2013 10:55 am
Hello dpatch,
First, I inform you that the TeeChartVCL (v2012.07.121105) included x32 and x64 bits. I check it here and appears x64 bits as you can see in next image:
Is possible your path are incorrect, because using last version of TeeChartVCL (v2012.07.121105) source code I haven't found any problems. Please following next steps to try to solve the problem:
1.- Install the last version of TeeChartVCL Source Code v2012.07.121105.
2.- Open Teerecompile as included in this version.
3.- Check your path is correct, you should have a similar path:
C:\Program Files\Steema Software\TeeChart Pro 2012 Full Source Code\Sources
If you have a different path please, change it.
4.- Selected option to compile RAD XE3.Win64 v17 Architect (RAD XE v10 Architect) (C++) and click begin.
Can you tell us if previous steps help you to solve the problem?
dpatch
Re: Recompile error
Post by dpatch » Tue Mar 19, 2013 12:41 pm
Yes, this issue can be closed...Thank you.
The problem was the path in your list numbered 3. It was pointing to TeeChart Pro 8.08 Full Source Code instead of 2012. I suspect this is a bug in the installation program for the 2012 version since I never installed the source code for 8.08
Thanks again!
Re: Recompile error
Post by Sandra » Tue Mar 19, 2013 3:18 pm
Hello dpatch,
I am glad that you have been solved your problem :D.
