Problem with "horizontal area"
rxrx12
Post by rxrx12 » Thu Feb 07, 2013 8:52 pm
How to clean the red line (serie1 color) at the left side?
It appears in design mode and run mode. With inverted bottom axis there is no such problem.
For removal it is enough to repaint a chart. But it isn't correct.
Source code attached. Just run.
Delphi 7
TeeChart 8.08.80307
Test.7z
(281.23 KiB) Downloaded 291 times
Re: Problem with "horizontal area"
Post by Yeray » Fri Feb 08, 2013 9:28 am
I could reproduce the problem with v8 but it seems to be fixed with the latest version.
Give it a try
