Hello all,
I am completely stack with this so I need a fresh look from someone else!!! I created this chart, works as I want to but it looks like I cannot hide one name group, for example I need the user to be able to show/hide Name1 or Name2 etc. Any help please !!!!
Need some help for a simple task!!!
- Untitled-1.gif (5.53 KiB) Viewed 10138 times
Re: Need some help for a simple task!!!
Hi Johnnix,
Could you please clarify if you want to hide just the "Name2" text, or also the bars above it?
I need to hide both label and bars
Hi Johnnix,
Then, I'd work with null points. Known the ValueIndex to hide, you can loop all your series and set as null:
Chart1[i].SetNull(ValueIndex);
Hi again,
In addition to the above, when I tried the following code, where I have 5 TBarSeries with 5 values each and I want to hide the ValueIndex=2:
I've seen the bars with ValueIndex=2 are correctly hidden, but not the bottom axis label.
However, you can always hide those labels in the bottom axis with no visible value associated:
And the above seems to work fine for me here.
uses Series;
var i, j, ValueIndex: Integer;
Chart1.View3D:=false;
for i:=0 to 4 do
with Chart1.AddSeries(TBarSeries) do
FillSampleValues(5);
Marks.Visible:=false;
for j:=0 to Chart1[i].Count-1 do
Chart1[i].Labels.Labels[j]:='Name'+IntToStr(j+1);
ValueIndex:=2; //ValueIndex to hide
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
var i: Integer;
if (Sender=Chart1.Axes.Bottom) and (ValueIndex>-1) then
if Chart1[i].IsNull(ValueIndex) then
if i=Chart1.SeriesCount-1 then
LabelText:='';
end
exit;
Hello Yeray,
Thank you very much for the prompt reply, I will give it a try !!!
Kindest regards
Kindest regards
