I try to export a dbchart with xvalues
It works if the xvalues i 0,1,2,3 but not if it is 1,2,3,4
Jørgen
HTML5 export xvalues does not work as expected
- XPos.zip
- (129.54 KiB) Downloaded 558 times
Re: HTML5 export xvalues does not work as expected
Hi Jørgen,
This should be fixed for the next TeeChart JavaScript maintenance release.
I've sent you the actual version for testing purposes as mentioned here
