TCHart has trouble handling dates < 1895
Open a chart (eg in TeeChartOffice)
Add a (bar) series
make bottom axis exact datetime, interval 1 year
ensure round first label is checked
add/change a data point so it is before 1895, eg 01-01-1850
Crash: EInvalidOp casued by routine that tries to determine the length of the rounded label. Actually the EInvalid op is raised inside the RTL because a way to large negative value is passed to the DateTImeToStr routine. the value is calculated as 365 * AxisMinimumDate
What happens is here is that a date (float days) is multiplied with the # of days in a year, and then pass it on to DAteTimeToStr. Happens earlier buiolds and also with the build I downloaded today: 2012.05.120327
Regards - Hans
Add a (bar) series
Regards - Hans
Re: TCHart has trouble handling dates < 1895
Hi Hans,
I'm not able to reproduce the issue either at design-time nor at run-time using this code snippet:
Does this work fine at your end? Can you modify the code snippet so that we can reproduce the issue here?
uses Series;
Chart1.AddSeries(TBarSeries.Create(Self));
Chart1[0].XValues.DateTime:=True;
Chart1.Axes.Bottom.ExactDateTime:=True;
Chart1.Axes.Bottom.Increment:=DateTimeStep[dtOneYear];
Chart1.Axes.Bottom.RoundFirstLabel:=True;
Chart1.Axes.Bottom.DateTimeFormat:='dd/mm/yyyy';
Chart1[0].AddXY(EncodeDate(1850, 1, 1), random);
Can you reproduce this issue outside TeeChart? It might be a RTL problem.Actually the EInvalid op is raised inside the RTL because a way to large negative value is passed to the DateTImeToStr routine.
Unfortunately the TChartOffice.exe delivered with the binaries install wont start. I downloaded another one separately, but this one does not accept dates before 1900, they are truncated to 00:00:00
Tee9New_win32.exe ran just fine. I manage to reproduce the error like this:
Tab All features
Miscellaneous/Design options
Show editor
Add a new (bar series)
Add numeric data points: [-3650,10 ] [1,10] [3650,10]
Now set series horiz axis to datetime
goto bottom axis editor
select tab increament, CHange
Check extact datetime and Standard: One year
click OK
bang - the error.
I managed to reproduce it like this, using Delphi XE2, Update 4, Win32:
I have attached the XE2 project I use for reproducing the error.
regards - Hans
Tab All features
Show editor
click OK
bang - the error.
procedure TfrmMain.btDateTroubleClick(Sender: TObject);
VAR y:integer;
sr:tChartSeries;
sr:=Chart1.AddSeries(TBarSeries.Create(Self));
sr.XValues.DateTime:=True;
for y:=1850 to 2012 do
sr.AddXY(EncodeDate(y,1,1),random(100));
procedure TfrmMain.btNoDateTroubleClick(Sender: TObject);
VAR y:integer;
sr:tChartSeries;
for y:=1896 to 2012 do
regards - Hans
- DateTrouble.part2.rar
- (287.44 KiB) Downloaded 1141 times
- DateTrouble.part1.rar
- XE2 demo case demonstrating the date problem
- (512 KiB) Downloaded 1216 times
Hi Hans,
We could reproduce it now with XE2, and we have a fix proposal you could try (since you are a source code customer).
In VCLTee.TeEngine.pas, in the function:
Change the line:
For:
Please, confirm us this solves the problem for you so we can apply the fix in the next maintenance release.
Function TChartAxis.LabelValue(Const Value:Double):String;
DateTimeToString(result,tmp,Value);
DateTimeToString(result,tmp,Abs(Value));
Hi Yeray
I am afraid your solution introduces a new error because it will not be able to generate labels for dates before 31-12-1899.
The labels would be translated into dates after the delphi "0" date because of thre abs call.
Here;'s the solution I came up with, and which seems to work as required.
Function TChartAxis.InternalLabelSize(Const Value:Double; IsWidth:Boolean):Integer;
var ...
v:double;
Begin
{$ifdef HH_PATCH_TC_MINDATE}
v:=Value;
if ExactDateTime then
begin // avoid invalid dates
v:=Max(v,EncodeDate(1,1,1)); // consider changing this into a const
v:=Min(v,EncodeDate(9999,12,31)); // consider changing this into a const
result:=ParentChart.MultiLineTextWidth(LabelValue(V),tmp);
{$else}
result:=ParentChart.MultiLineTextWidth(LabelValue(Value),tmp);
{$endif}
Hi Hans,
- It still fails if you have ExactDateTime to true.
- If anyone wants a date before 1/1/1, it'll be truncated to 1/1/1.
I've added it to the wish list to be further investigated for future releases (TV52016171). Of course, in the meanwhile, feel free to use your patch.
RightH.Hasenack wrote:I am afraid your solution introduces a new error because it will not be able to generate labels for dates before 31-12-1899.The labels would be translated into dates after the delphi "0" date because of thre abs call.
I'm not sure if that's a definitive solution either:H.Hasenack wrote:Here;'s the solution I came up with, and which seems to work as required.![]()
Does it ? - at least it works just fine in my tests...- It still fails if you have ExactDateTime to true.
Well, that allows for an additional 1895 years of history. I must say, using pre-historic dates (29/02/-100) did not spring into my mind as a real issue. Maybe the guys that actually do that dont use TDateTime and ExacteDateTime for producing their date- If anyone wants a date before 1/1/1, it'll be truncated to 1/1/1.
Anyway I'm away for a week's holiday, I'll see what you came up with next week.
Regards - hans
Hi Hans,
Oups, I meant it still fails if you have ExactDateTime to false.
The fix was easy and simple... Just use IsDateTime instead of ExactDateTime
It works like a charm, independent of the ExactDateTime value. Also I precalculated the values to optimize the code.
The final patch would then look like tis:
v:=Value;
if IsDateTime then
v:=Max(v,-693593); //Max(v,EncodeDate(1,1,1));
v:=Min(v,2958465); //Min(v,EncodeDate(9999,12,31));
{$else}
{$endif}
Hi Hans,
Now the only aspect in this suggestion that still makes me doubt is this:
Actually, I think no date should be truncated as far as possible, even if it's just a label and not the real XValue what we are manipulating here.
Also note this happens with the automatic labels; one can always use custom labels to draw any date in the history of the universe.
Anyway, I'd like to thank you for your feedback and suggestions. We appreciate it.
Yep. This looks more logical to me.H.Hasenack wrote:The fix was easy and simple... Just use IsDateTime instead of ExactDateTime
I still think dates before 1/1/1 shouldn't be truncated. I don't see why dates before 1/1/1 wouldn't be plotted. Or at least I don't understand the 1/1/1 as a line separating what can be dated&plotted and what can't.H.Hasenack wrote:Well, that allows for an additional 1895 years of history. I must say, using pre-historic dates (29/02/-100) did not spring into my mind as a real issue. Maybe the guys that actually do that dont use TDateTime and ExacteDateTime for producing their dateyeray wrote:- If anyone wants a date before 1/1/1, it'll be truncated to 1/1/1.![]()
In this case you'd have to write your own DateTimeToStr routines, as the XE2 VCL raises an exception if the date is before 01-01-0001
The other limit (31-12-9999) was just introduced by myself for completeness.
Moreover, this is the routine that determines the label size, not the plotting routine itself.
I did not test, but it is very likely that plotting labels before 01-01-0001 will still raise the error. Whether its a VCL bug or feature: I think it's a feature since the VCL explicitly checks for this value limits and raises the exception.
I hope the change makes it into the next release, for now I'll keep my patch.
Regards - Hans
Regards - Hans
