XE2 Update #4; Quickreport 5: How to install qrChart
Philip
Post by Philip » Sun Mar 25, 2012 7:02 pm
Hi all,
how can I install qrChart for quickreport 5. In my source files there is no DclTee9QR5D16.
Thanks for replay.
Philip
Re: XE2 Update #4; Quickreport 5: How to install qrChart
Post by Narcís » Mon Mar 26, 2012 7:33 am
Hi Philip,
What about the packages at the Delphi16.win32\QuickReport folder? You should follow the instructions at Install.txt there and the QuickReport article here.
Hope this helps.
Philip
Post by Philip » Mon Mar 26, 2012 5:17 pm
There is no Quickreport-Folder, even if I check "Quickreport" in the Recompile tool
Post by Yeray » Tue Mar 27, 2012 9:06 am
- Binary installation: DclTQR916 and TeeQR916 (.dpk and .res) are in the "\Delphi16.win32\QuickReport" folder.
- Source Code installation: DclTQR916 and TeeQR916 (.dpk and .res) are in the "\Sources" folder.
You should check the references on them and build&install them; you could optionally rename them to DclTee9QR5D16 and Tee9QR5D916 (.dpk and .res) before.
Read the QuickReport article here to know how to do it.
