Delphi XE2 Update2: DCC Warning in TeCanvas.pas
Tom
Post by Tom » Wed Nov 23, 2011 11:20 am
Hello
When compiling the new version (2011.04.41118) in Win32-bit mode I get a warning in TeCanvas.pas
Could you remove this warning in the next release?
Best regards
Tom
[DCC Warning] VCLTee.TeCanvas.pas(7623): W1036 Variable 'tmpRes' might not have been initialized
It is on the line 'Assert(tmpRes,'Error transferring internal Bitmap using BitBlt');' in this code:
Procedure TTeeCanvas3D.TransferBitmap(ALeft,ATop:Integer; ACanvas:TCanvas);
{$IFNDEF FMX}
{$IFOPT C+}
var tmpRes : LongBool;
{$ENDIF}
{$ENDIF}
  {$IFNDEF CLX}
  {$IFDEF MONITOR_REPAINTS}
  Inc(TeeMonitor);
  FBitmap.Canvas.TextOut(0,0,IntToStr(TeeMonitor));
  {$ENDIF}
//  Assert(FBitmap.PixelFormat=pfDevice,'Buffer Bitmap PixelFormat <> pfDevice');
  {$IFDEF LCL}
  ACanvas.Draw(ALeft, ATop, FBitmap);
  {$ELSE}
  {$IFDEF FMX}
  {$ELSE}
  if View3DOptions.Parent.Parent<>nil then
  {$IFOPT C+}
  tmpRes:=
  {$ENDIF}
  BitBlt( ACanvas.Handle,ALeft,ATop,
          FBitmap.Width,
          FBitmap.Height,
          FBitmap.Canvas.Handle,0,0,SRCCOPY);
  {$IFOPT C+}
  {$IFNDEF TEEOCX}
  {$ENDIF}
  {$ENDIF}
  {$ENDIF}
  {$ENDIF}
  {$ELSE}
  QPainter_drawPixmap(ACanvas.Handle, ALeft, ATop, FBitmap.Handle, 0, 0,
    FBitmap.Width, FBitmap.Height);
  {$ENDIF}
Re: Delphi XE2 Update2: DCC Warning in TeCanvas.pas
Post by Yeray » Thu Nov 24, 2011 8:19 am
Hi Tom,
Yes, we are aware of this warning. As you've probably seen looking at the conditions, this variable won't be used without being defined. But anyway, we'll try to clean the warning messages in future releases.
Tom
Post by Tom » Fri Nov 25, 2011 7:05 am
thank you.
In the mean time I suppress the warning by adding the following code at the beginning of the method:
  {$IFNDEF CLX}
// changes start
  {$IFOPT C+}
  tmpRes:= False;
  {$ENDIF}
// changes end
Best regards
Tom
