Show/Hide individual Axis Custom Labels
Piero
Post by Piero » Wed Oct 12, 2011 11:39 am
Hello, I'm having this type of problem with axis custom labels:
I have a TChart in which I dynamically create a set of TBarSeries, each one having a single bar value. I want to display in the bottom axis a string of text under each bar. I do this by adding custom labels to the chart BottomAxis:
      for i:=0 to NSeries-1 do
            Series:=TBarSeries.Create(Chart);
            Series.AddXY(i,Values[i,0]);
            Chart.BottomAxis.Items.Add(i,SeriesTitles[i]);
            Series.ParentChart:=Chart;
This works. But then, I want to show/hide the above custom labels depending on which series are made visible by the user. I try do it in this way:
with Chart do
      for i:=0 to SeriesCount-1 do
         if (Pos('1',Series[i].Title) <> 0) then   // criteria that I'm using to decide wheter a series should be shown or not
               Series[i].Active:=true;
               BottomAxis.Items[i].Format.Visible:=true;
            end
               Series[i].Active:=false;
               BottomAxis.Items[i].Format.Visible:=false;
Chart.Refresh;
but this doesn't work, because all custom labels previously defined are always displayed, independently if the corresponding Series is active or not.
I think there should be some other BottomAxis property to be set to get the desired result, but I cannot find which one niether from help nor from examples.
Thank you very much for your help.
Piero
Re: Show/Hide individual Axis Custom Labels
Post by Yeray » Fri Oct 14, 2011 8:15 am
Hello Piero,
It seems that the Items.Format.Visible property isn't hiding the custom labels. I've added it to the wish list to be investigated for future releases (TV52015785).
In the meanwhile I'm afraid the only solution I can think is drawing the labels manually in the OnAfterDraw event, and control there if a label should be drawn or not.
var i: Integer;
    if Chart1[i].Active then //add your condition here
      Chart1.Canvas.TextOut(Chart1[i].CalcXPos(0), Chart1.Axes.Bottom.PosAxis+5, SeriesTitles[i]);
Piero
Post by Piero » Fri Oct 14, 2011 2:13 pm
Hello Yeray,
your workaround is fine, I implemented it in my software and it does exactly what I desired!
Piero
Post by Yeray » Mon Oct 17, 2011 9:14 am
Hello Piero,
I'm glad to hear that! :)
