TTeeCanvas.ClipPolygon has a compile hint
mcdurdin
Post by mcdurdin » Wed Oct 05, 2011 9:52 pm
When compiling the source of TeeChart Pro 2011.03.30407, in TeCanvas.pas, TTeeCanvas.ClipPolygon has a compiler hint:
[DCC Hint] TeCanvas.pas(6040): H2077 Value assigned to 'Region' never used
I'm guessing that you'd prefer TeeChart source code to not be posted on your forum so I'm just going to ask Steema to fix this and not discuss our (straightforward) patch here.
It'd *really* help if there was a private way to report issues like this where attaching your source code was not an issue. Given the price of TeeChart, I really think you could do better than releasing code with obvious issues like this that the compiler even highlights for you.
Re: TTeeCanvas.ClipPolygon has a compile hint
Post by Yeray » Fri Oct 07, 2011 1:14 pm
If you want to put here a little portion of TeeChart source code it's not an inconvenient for us. If you prefer to discuss it in private, don't hesitate to mail us at "info at steema dot com".
We've corrected some warnings between v2011.03 and v2011.04. You can try the v2011.04 Pre-Release to see it.
