Chart formats strange at runtime after dynamic code
Metegrity Inc.
Post by Metegrity Inc. » Fri Aug 26, 2011 6:00 pm
Please could someone help clarify this for me ASAP (I'm in the middle of finalizing a project, need the graphs to format better).
Scenario:
I'm adding values to the TeeChart dynamically (including custom axes, series, and series values).
I get the desired results with the exception of the chart not formatting nicely (like it does when it's set up via the wizard).
I'm sure it's just a matter of refreshing the template or something like that, I just don't know how!
Here are my examples:
This is how the original graph looks like
This is how my new graph looks like
My main concern at this point is the following:
I need my new graph to only show bottom axis label for where there are records (just like the first one)
I need the graph to show xy axis labels where there are records (just like the first one)
I need the left margin to adjust automatically to show the full reading labels and axis titles (just like the first one)
Please advise, I need this ASAP since we're supposed to release soon!
FYI: here is some of the sample code, just snippets not the entire function (I don't think you really need it but just so you know how I'm doing this):
fraPCTGraphByAnalysis.chtGraph.CustomAxes.Clear;
fraPCTGraphByAnalysis.chtGraph.RemoveAllSeries;
Adding the custom axes:
         sgSeriesGroup := fraPCTGraphByAnalysis.chtGraph.SeriesList.AddGroup(slProductTypes[i]);
         caAxis := fraPCTGraphByAnalysis.chtGraph.CustomAxes.Add as TChartAxis;
         caAxis.Title.Angle := 90;
         caAxis.Title.Caption := slProductTypes[i];
         caAxis.StartPosition := iAxesStart;
         caAxis.EndPosition := iAxesStart + iAxesSize;
         caAxis.AxisValuesFormat := '#0.000';
Adding the series:
         for i2 := 0 to slChemicalComponents.Count - 1 do
            csSeries := TLineSeries.Create(self);
            csSeries.Pointer.Visible := true;
            csSeries.Pointer.Size := 2;
            csSeries.Title := slChemicalComponents[i2];
            csSeries.CustomVertAxis := caAxis;
            csSeries.XValues.DateTime := true;
            sgSeriesGroup.Add(csSeries);
            fraPCTGraphByAnalysis.chtGraph.AddSeries(csSeries);
Adding the values:
         for i2 := 0 to Length(aReadingRecord) - 1 do
            //consider records that only belong to this Product group (for loop "i")
            if aReadingRecord[i2].sProduct = caAxis.Title.Caption then
               //get the series in the current Product group
               for i3 := 0 to sgSeriesGroup.Series.Count - 1 do
                  if aReadingRecord[i2].sSeries = sgSeriesGroup.Series[i3].Title then
                     sgSeriesGroup.Series[i3].AddXY(aReadingRecord[i2].dTestDate,aReadingRecord[i2].fReading);
Metegrity Inc.
Re: Chart formats strange at runtime after dynamic code
Post by Metegrity Inc. » Mon Aug 29, 2011 3:10 pm
Of course I forgot to mention the version.
v8.01.10798 Win32
Can we please get some help with this issue?
Post by Yeray » Tue Aug 30, 2011 7:48 am
Excuse us for the delayed reply.
Metegrity Inc. wrote:I need my new graph to only show bottom axis label for where there are records (just like the first one)
In the actual TeeChart there is a new axis LabelStyle, named talPointValue that would do it for you.
However, in v8 I'm afraid it doesn't exist. The easiest way to do it is to add your points with the labels and use talText LabelStyle. The label entered would be the string taken from the XValue datetime.
Metegrity Inc. wrote:I need the graph to show xy axis labels where there are records (just like the first one)
Isn't this the same than above? If not, please try to explain it again.
Metegrity Inc. wrote:I need the left margin to adjust automatically to show the full reading labels and axis titles (just like the first one)
The custom axes don't do it by default. But you always can add some LeftMargin considering the axis MaxLabelsWidth. Something as follows:
  chtGraph.MarginUnits:=muPixels;
  chtGraph.MarginLeft:=caAxis.MaxLabelsWidth + caAxis.TickLength + 5;
And don't forget that the chart needs to be drawn for the MaxLabelsWidth to have a valid value. So call chtGraph.Draw before the above if necessary.
Metegrity Inc.
Post by Metegrity Inc. » Tue Aug 30, 2011 1:56 pm
Thank you for the reply.
I will try the mentioned methods and will let you know if I have any further questions.
Metegrity Inc.
Post by Metegrity Inc. » Tue Aug 30, 2011 5:14 pm
Awesome, it's starting to look like a proper graph now :) (of course I got more tweaking to do).
One more thing though, I'm wondering if I can somehow expand the series coloring theme.
If you notice, after some of the series they stop having a color associated with them and they are all assigned to gray (ignore the repeated "black" series, that's just the downsizing of the .jpg image, but after the "white" H+ the gray color repeats).
How can I solve that problem?
Post by Yeray » Wed Aug 31, 2011 8:38 am
Metegrity Inc. wrote:Awesome, it's starting to look like a proper graph now :) (of course I got more tweaking to do).
I hope so! :)
Metegrity Inc. wrote:One more thing though, I'm wondering if I can somehow expand the series coloring theme.
By default, the OperaPalette is used to color your series. This palette is an array of 12 colors. If you want, you can create your custom palette and/or make your series use that palette restarting from its first color after using its last color. Something like following:
  for i:=0 to 30 do
    with Chart1.AddSeries(TPointSeries) do
      FillSampleValues(5);
      Color:=OperaPalette[i mod Length(OperaPalette)];
Metegrity Inc.
Post by Metegrity Inc. » Fri Sep 02, 2011 7:49 pm
Yeray wrote:Hello,
  for i:=0 to 30 do
Wonderful, that helps!
Metegrity Inc.
Post by Metegrity Inc. » Tue Sep 06, 2011 8:27 pm
I am nearly ready to finalize the graph, but I do require some assistance with one rather annoying issue:
I highlighted which values are not showing on the grid/bottom axis.
The values are there but for some reason they don't always show on the axis. I need them to be there.
Is there a way I can force this to happen? I have the ShowAllLables enabled on the bottom axis (in the Chart wizard, not in code).
As I disable so of the Product Type (Gas, Condensate, Liquids) they values start appearing on the bottom axis, so I know the graph "knows" what they are!
For example if I disable Gas I can see ALL the labels for the Condensate axis but none of the Liquids axis labels, but when I only have the Liquids enabled I see all of it's labels.
Here is a stub of what the process of creating all of that stuff is:
First I make a list of the Product Types
      with TdtmPLProductContentTesting(miDataModule) do
         SetLength(aReadingRecord, cdsGraph.RecordCount);
         i:=0;
         while not cdsGraph.Eof do
//DO STUFF HERE
            cdsGraph.Next;
         end;//while not cdsGraph.Eof do
         cdsGraph.First;
      end;//with TdtmPLProductContentTesting(miDataModule) do
Then we get into setting up the graph:
      for i := 0 to slProductTypes.Count - 1 do
         //CREATE THE AXES HERE
         //CREATE THE SERIES LIST HERE
            //consider records that only belong to this Produc group (for loop "i")
               slSeries.Add(aReadingRecord[i2].sSeries);
         //add the series groups to the graph
         for i2 := 0 to slSeries.Count - 1 do
             //ADD THE LINE SERIES TO THE GRAPH IN HERE
         end;//for i2 := 0 to slChemicalComponents.Count - 1 do
         //attach values to the series
                  if (aReadingRecord[i2].sSeries+' ('+
                     dtmLKLookup.ldsTLTranslationTable.Lookup('TRANSLATIONID',
                     slProductTypes[i],'FIELDLABEL')+')') = sgSeriesGroup.Series[i3].Title then
                        aReadingRecord[i2].fReading,
                        DateToStr(aReadingRecord[i2].dTestDate));
                  end;//if aReadingRecord[i2].sSeries = sgSeriesGroup.Series[i3].Title then
            end;//if aReadingRecord[i2].sProduct = caAxis.Title.Caption then
         end;//for i2 := 0 to Length(aReadingRecord) - 1 do
Please let me know if you need more of the code, or any other samples/questions.
I assume it has something to do with the fact that I go through and add the new series, then the values, right after the axis is created? Maybe?
I don't want to change the code if you may have an idea of what the issue could be.
Otherwise I suppose I could try to add values to the series in a loop outside of the main "Axes" loop. So make the axes, make the series, exist loops and then go through the list of series and add their values then...?
Thank you!
Post by Sandra » Wed Sep 07, 2011 11:52 am
Hello Metegrity Inc,
I think that your problem is due you doesn't add labels for each point you have in the chart and leave the default labels in the bottom axis. I suggest a solution to arrange your labels, you only need use custom labels as do in next simple code, where is adding for each series points, a label:
procedure TForm3.FormCreate(Sender: TObject);
var i,j:Integer;
myDate:TDateTime;
Chart1.view3D:= false;
Series1.FillSampleValues(2);
Series2.FillSampleValues(3);
Series3.FillSampleValues(6);
Series1.Pointer.Visible:=true;
Series2.Pointer.Visible:=true;
Series3.Pointer.Visible:=true;
Series1.XValues.DateTime:=True;
Series2.XValues.DateTime:=True;
Series3.XValues.DateTime:=True;
Chart1.Legend.CheckBoxes:=True;
Chart1.Axes.Bottom.Items.Clear;
for i := 0 to Chart1.SeriesCount- 1 do
For  j:=0 To Chart1[i].Count-1 do
        Chart1.Axes.Bottom.Items.Add(Chart1[i].XValues[j],FloatToStr(Chart1[i].XValues[j]));
Chart1.Axes.Bottom.LabelsAngle:=90;
Please, can you tell us if previous code solves your problem with labels?
Metegrity Inc.
Post by Metegrity Inc. » Wed Sep 07, 2011 3:51 pm
Sorry, I know my code may be a little confusing unless viewed and understood in the full spectrum.
I do in fact, though, add a Label to every reading (or Point):
So every Point on the graph does have a Label associated with it.
I must add the XY values hence I'm using the AddXY code.
The graph is broken into series which belong to different Y axes that's why my code looks the way it does.
Also, there is no Add function that takes 2 arguments for Axes.Bottom.Items, it takes only one argument that's a double (for my version anyways).
I was trying to play around with some of your suggestions, but it's not working out.
I will keep trying, perhaps there is something else we can do?
Metegrity Inc.
Post by Metegrity Inc. » Wed Sep 07, 2011 7:08 pm
I went around a different route, however it still get a similar (and undesired) result.
But, at least this code should be easier to understand.
So omitting how I create the records, axes, groups, this I believe makes a little bit more sense as a "stand alone" code:
      with fraPCTGraph.chtGraph do
         for i := 0 to SeriesGroups.Count - 1 do
            for i2 := 0 to SeriesGroups[i].Series.Count - 1 do
               for i3 := 0 to Length(aReadingRecord) - 1 do
                  if (aReadingRecord[i3].sProduct = SeriesGroups[i].Name) AND
                     (aReadingRecord[i3].sSeries+' ('+SeriesGroups[i].Name+')'
                        = SeriesGroups[i].Series[i2].Title)
                  then
                     SeriesGroups[i].Series[i2].AddXY(aReadingRecord[i3].dTestDate,
                        aReadingRecord[i3].fReading,
                        DateToStr(aReadingRecord[i3].dTestDate));
               end;//for i3 := 0 to Length(aReadingRecord) - 1 do
            end;//for i2 := 0 to SeriesGroups[i].Series.Count - 1 do
         end;//for i := 0 to SeriesGroups.Count - 1 do
         Draw;
         MarginUnits := muPixels;
         MarginLeft := CustomAxes[0].MaxLabelsWidth + CustomAxes[0].TickLength + 25;
         MarginRight := 35;
      end;//with fraPCTGraphByAnalysis.chtGraph do
It, just like the other way around, works just fine. Adds correct values to correct axes and series, just the labels are still missing from some values :(
Post by Sandra » Thu Sep 08, 2011 12:02 pm
Hello Metegrity Inc.
We have made a simple code to try to reproduce your problem here:
Uses Series,Math, TeCanvas;
var i,j:Integer;
    Green,Blue : TChartAxis;
    Series1, Series2, Series3: TLineSeries;
    tmp: TDateTime;
  Series1:=Chart1.AddSeries(TLineSeries) as TLineSeries;
  Series2:=Chart1.AddSeries(TLineSeries) as TLineSeries;
  Series3:=Chart1.AddSeries(TLineSeries) as TLineSeries;
  tmp:=Date;
  Series1.AddXY(tmp+3,15,DateToStr(tmp+3));
  Series1.AddXY(tmp+7,20, DateToStr(tmp+7));
  Series2.AddXY(tmp+4,10,DateToStr(tmp+4));
  Series2.AddXY(tmp+15,25,DateToStr(tmp+15));
  Series2.AddXY(tmp+22,50,DateToStr(tmp+22));
  Series2.AddXY(tmp+12,30,DateToStr(tmp+12));
  Series3.AddXY(tmp+21,110,DateToStr(tmp+21));
  Series3.AddXY(tmp+23,30,DateToStr(tmp+23));
  Series3.AddXY(tmp+11,55,DateToStr(tmp+11));
  Series1.Pointer.Visible:=True;
  Series2.Pointer.Visible:=True;
  Series3.Pointer.Visible:=True;
  Chart1.View3D:=False;
  Chart1.Legend.Visible:=false;
  { change the Left axis properties }
  With Chart1.LeftAxis do
    Axis.Color:=Series1.Color;
    StartPosition:=0;
    EndPosition:=33;
  { create custom axes. This can be done at design-time
    with the chart editor. }
  Green:=TChartAxis.Create(Chart1.CustomAxes);
  With Green do
   Axis.Color:=Series2.Color;
   StartPosition:=33;
   EndPosition:=66;
  Blue:=TChartAxis.Create(Chart1.CustomAxes);
  With Blue do
   Axis.Color:=Series3.Color;
   StartPosition:=66;
   EndPosition:=100;
  { associate series }
  Series1.VertAxis:=aLeftAxis;
  Series2.CustomVertAxis:=Green;
  Series3.CustomVertAxis:=Blue;
  { use custom labels }
      Chart1.Axes.Bottom.Items.Add(Chart1[i].XValues[j], DateToStr(Chart1[i].XValues[j]));
Testing previous code, in last version of TeeChartVCL(build 8.08.80307), we couldn’t reproduce your problem and we can see, there are three overloads of method Add with next headers:
Function TAxisItems.Add(const Value: Double):TAxisItem;
Function TAxisItems.Add(const Value: Double; const Text: String):TAxisItem;
Function TAxisItems.Add(const Value: Double; const Text:String; const Font:TTeeFont):TAxisItem;
So, I recommend you, update your version 8 of TeeChartVCL to last release, you can find in this link and check again if your problem persists. On the other hand, if you have any reason that you don't allow update your version, please let me know.
Metegrity Inc.
Post by Metegrity Inc. » Thu Sep 08, 2011 2:16 pm
So what you're saying is that there are no overloads of that method in my version, is that correct?
We will for sure not upgrade before the release which is coming up at the end of the week (relatively speaking), but we may consider that for further version (just to avoid any issues with our graphs, we have quite a few in our software).
Post by Sandra » Fri Sep 09, 2011 1:25 pm
So sorry, I think, I haven't explained well, I wanted tell, you have different overloads of add method, to add labels in the axis items. Is also true, that in last version 8 there are some modifications may be useful you to achieve as you want and improve performance of your application.
Thank you.
Metegrity Inc.
Post by Metegrity Inc. » Sat Sep 10, 2011 9:11 pm
AHA!
YES!
Sorry, for some reason I "wasn't seeing" the overloads, but they are in fact there.
Anyways your solution worked!
Thank you! That makes the graph pretty much bug free as far as I'm concerned right now :)
