GDI+ switched-off Chart Tools
mfehr
Post by mfehr » Sat Aug 13, 2011 10:51 am
A Chart tool calculates a band between tow series.
On "TeeGDIPlus1.Active := false;" this works pretty good but on "TeeGDIPlus1.Active := true" the band has been switched off or to transparent color.
How can I fix this?
This pictures show the difference if TeeGDIPlus1.Active is set.
Re: GDI+ switched-off Chart Tools
Post by Yeray » Tue Aug 16, 2011 8:03 am
It seems to work fine for me here with the latest version (v2011.03), both running the demo under All features\Welcome !\Tools\Series Band and a simple example application with the following code:
uses Series, TeeSeriesBandTool, TeeGDIPlus;
  Chart1.Canvas:=TGDIPlusCanvas.Create;
  Chart1.View3D:=false;
  Chart1.AddSeries(TLineSeries).FillSampleValues();
  with Chart1.Tools.Add(TSeriesBandTool) as TSeriesBandTool do
    Series:=Chart1[0];
    Series2:=Chart1[1];
    Gradient.Visible:=true;
    Transparency:=50;
PS: I've moved this topic to the TeeChart\VCL forums.
mfehr
Post by mfehr » Wed Aug 24, 2011 1:48 pm
Hello Yeray,
Thank you for your replay!
For me it looks like an inverted tape color.
I've changed the chart.tool.transparence to 50%.
On GDI+=off I can see the expected grey tape.
On GDI+=ON now I see a transparent white tape.
How can I change the tool.tape color on running time?
This might solve my problem?
Best regards!
Matthias
Post by Yeray » Fri Aug 26, 2011 3:39 pm
Hello Matthias,
You can change the tool color with its property Brush.BackColor. But note that this will only be applied when the tool property Gradient.Visible is false.
What TeeChart version are you using?
mfehr
Post by mfehr » Sat Aug 27, 2011 7:33 pm
Hello Yeray,
The tip does not work here but I found a solution.
I've set the the tool gradient twice to grey.
This has been "solved" the problem.
I do use the April 11 version.
Regards!
Matthias
Post by Sandra » Wed Sep 07, 2011 9:06 am
Hello mfehr,
Thanks for your information. I am glad that you have solved your problem.
