never ending dll-process
UFriedrich
Post by UFriedrich » Mon Dec 06, 2004 11:03 pm
Hi all,
i have tested a short dll for using in IIS. In this dll I use a chart. So good so far, it works fine. If I add a part like this:
assignfile(TXF, 'C:\Test\example.txt');
reset(TXF);
while not EOF(TXF) do
do anything;
closeFile(TXF);
the dll runs and runs and runs .....
If I put this source snippet in a normal app it works fine, but in a webserver app it does not.
I have no idea :(
Can anybody help me???
Greetings
U. Friedrich
Post by Pep » Tue Dec 07, 2004 11:03 am
Hi Friedrich,
which error appears ?
UFriedrich
Post by UFriedrich » Wed Dec 08, 2004 9:10 am
Hi pep,
the problem above is solved, but I have a new prob.
Here is a small snippet of code that works correct.
ImageStream := TStream;
tmp := TGIFExportFormat.Create;
tmp.Panel := Chart1;
Series1.FillSampleValues(100);
tmp.SaveToStream(ImageStream);
If I change the procedure from "Series1.FillSampleValues" to "Series1.AddXY" it results in a "Access violation at address 00403E2D in module 'hs.exe'. Read of address 00000000 "
Here is the changed code from above.
for i := 0 to 500 do
Series1.AddXY(i,y);
//Series1.FillSampleValues(100);
Thank you for help
