EInvalidOperation with SubChart and MarksTipTool
WilliEbert
Post by WilliEbert » Wed Apr 13, 2011 2:42 pm
Hello
I've get always a EInvalidOperation (with message 'SubChart' has no parent window) if the SubChart has a MarksTipTool assigned to a series as Tool and the cursor hovers over the series in the SubChart. The error occurs in line 574 of TSubChartTool
if (not AllowDrag) then
-> TChartAccess(FChart).MouseMove(Shift,X,Y);
Can you help me?
Your sincerely
Willi Ebert
Re: EInvalidOperation with SubChart and MarksTipTool
Post by Yeray » Wed Apr 13, 2011 4:33 pm
Hello Willi,
I've been able to reproduce the problem so I've added it to the defect list to be fixed in future releases (TV52015496).
In the meanwhile, you could work with OnMouseMove event as in the example below:
procedure Chart2MouseMove(Sender: TObject; Shift: TShiftState; X, Y: Integer);
uses Chart, TeeSubChart, Series, TeeTools;
var Chart1, Chart2: TChart;
    SubChart1: TSubChartTool;
  Chart1:=TChart.Create(self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.Legend.Visible:=false;
  Chart1.View3D:=false;
  Chart1.AddSeries(TPointSeries).FillSampleValues();
  SubChart1:=(Chart1.Tools.Add(TSubChartTool) as TSubChartTool);
  Chart2:=SubChart1.Charts.AddChart('');
  Chart2.View3D:=false;
  Chart2.AddSeries(TPointSeries).FillSampleValues();
  Chart2[0].Color:=OperaPalette[1];
  Chart2.Tools.Add(TAnnotationTool).Active:=false;
  Chart2.OnMouseMove:=Chart2MouseMove;
procedure TForm1.Chart2MouseMove(Sender: TObject; Shift: TShiftState; X, Y: Integer);
var ValueIndex: Integer;
    Annot: TAnnotationTool;
  Annot:=Chart2.Tools[0] as TAnnotationTool;
  ValueIndex:=Chart2[0].Clicked(X, Y);
  if ValueIndex>-1 then
    Annot.Active:=true;
    Annot.Text:=FormatFloat('##0,##', Chart2[0].YValue[ValueIndex]);
    Annot.Left:=X-SubChart1.Charts[0].Left;
    Annot.Top:=Y-SubChart1.Charts[0].Top-Annot.Height;
  end
    Annot.Active:=false;
WilliEbert
Post by WilliEbert » Wed Apr 13, 2011 5:08 pm
Hello Yeray,
thank you very much for your quick answer. But i do not fully understand your code. Lets say Chart1 is my main Chart, SubChart1 is the SubChart of Chart1. But why you use Chart2?
Your sincerely
Willi Ebert
Post by Yeray » Thu Apr 14, 2011 10:59 am
Hello Willi,
As you can see in the line:
Chart2 is the first chart in the SubChart Tool.
In other words:
SubChart1 is the same than (Chart1.Tools[0] as TSubChartTool)
Chart2 is the same than (SubChart1.Charts[0] as TChart) and the same than ((Chart1.Tools[0] as TSubChartTool).Charts[0] as TChart)
