BarSeries Stack invisible
GoToXY
Post by GoToXY » Fri Nov 05, 2010 3:29 pm
Hi Steema team.
I think i got a lil bug here with the BarSeries in stack mode.
Stacked 100% with 2 groups
Stacked with 2 groups
GoToXY
Re: BarSeries Stack invisible
Post by GoToXY » Fri Nov 05, 2010 3:31 pm
Forget to tell you some informations:
Delphi 2010
TChart 8.0.6
Windows 7
Post by Narcís » Fri Nov 05, 2010 3:34 pm
Hi GotoXY,
First of all please bear in mind that for using stacking all series need to have the same number of points and same X values. Having that in mind, does this also occur using v8.07 which is the latest build available at the client area? If the problem persists can you please attach a simple example project we can run "as-is" to reproduce the problem here?
GoToXY
Post by GoToXY » Fri Nov 05, 2010 3:50 pm
Oh ok, ill check the points count but for im sure all X Values are the same.
I dont have time right now to move to 8.0.7 because i had to change some stuff in your code to make it work like i need it (ex: DATA :Pointer; in a Series to keep tracks of lots of information)
GoToXY
Post by GoToXY » Fri Nov 05, 2010 3:56 pm
Ahhhh, i confirm that 2 of my series didnt have the same amount of points.
Thanks again, really appreciate your Superman Support ;)
have a nice day!
Post by Narcís » Fri Nov 05, 2010 4:04 pm
Hi GotoXY,
Ok, thanks for the info. If you have a simple application with which we can reproduce the issue here we will gladly look at it.
GoToXY
Post by GoToXY » Fri Nov 05, 2010 5:36 pm
I made one for you with 2 stacked groups. At least now, i know i have to verify how many points i have for each series and make them equal so that way it work perfectly.
BarSeriesStacked.zip
(7.76 KiB) Downloaded 546 times
Post by Narcís » Mon Nov 08, 2010 9:04 am
Hi GoToXY,
Thanks for the example project. In those cases where you don't want to plot a value for a series you should either add a zero point or a null point, for example:
Var
   TheDate : TDate;
   Ctr : Integer;
  TheDate := EncodeDate(YearOf(Now),MonthOf(Now),1);
  For Ctr := 1 To 12 Do
  Begin
    Chart1[0].AddXY(TheDate,Random(50)+50,MonthNames[MonthOf(TheDate)]);
    Chart1[1].AddXY(TheDate,Random(10)+10);
    If (Ctr Mod 2 = 0) Then
      Chart1[2].AddXY(TheDate,Random(10)+10)
      Chart1[2].AddNullXY(TheDate,0);
    If (Ctr Mod 3 = 0) Then
      Chart1[3].AddXY(TheDate,Random(10)+10)
      Chart1[3].AddNullXY(TheDate,0);
    If (Ctr Mod 4 = 0) Then
      Chart1[4].AddXY(TheDate,Random(10)+10)
      Chart1[4].AddNullXY(TheDate,0);
    Chart1[5].AddXY(TheDate,Random(10)+10);
    TheDate := IncMonth(TheDate);
  End;
GoToXY
Post by GoToXY » Tue Nov 09, 2010 12:33 pm
Yes this is exactly what ive done after i knew it was a points number issue. I had to do the same thing for the function (add,div etc..) to solve half of the problem.
