Memory Leak GDI+
José Araújo
Memory Leak GDI+
Post by José Araújo » Tue Aug 03, 2010 9:32 pm
I'd removed the line IXORCanvas:=TTeeCanvas3D.Create from InitWindow and put in the Constructor Create and trouble keep on.
What should I do now? Any solve else?
I'd sent a print screen from MM4.
thanks
print screen of the Application and MM4
Re: Memory Leak GDI+
Post by Yeray » Thu Aug 05, 2010 4:06 pm
Hi Fausto,
Why do you want to remove that line? We added it to fix these memory leaks.
José Araújo
Post by José Araújo » Thu Aug 05, 2010 5:25 pm
I´m using the >>>TeeChart Pro 2010 Full Source Code >>>Version 0.4455.0.0 and like you can see the Memory Leak keep on. Have you see the atachment file (print mm4) wich I sent you?
Post by Yeray » Thu Aug 05, 2010 7:41 pm
Hi Fausto,
You may be doing something different than me. Here is what I'm doing:
uses Series, TeeGDIPlus;
var FGDIPlus: TTeeGDIPlus;
  with Chart1.AddSeries(TBarSeries) as TBarSeries do FillSampleValues();
  FGDIPlus := TTeeGDIPlus.Create(Self);
  FGDIPlus.TeePanel := Chart1;
  ReportMemoryLeaksOnShutdown := True;
Could you please modify the example above so we can reproduce the error here?
José Araújo
Post by José Araújo » Thu Aug 12, 2010 1:46 pm
If you change the transparency of the WALLS you can memory on. In your example you forgot put the GDIPlus (Active = True).
I'd attached other example. I my example you should use the ROTATE TOOL and you can see the memory usage UP and UP UP UP UP.
delphi7
MEMORY leak_FAUSTO.rar
example in delphi7 with WALLS (transparency 70%) and memory leak on
(29.67 KiB) Downloaded 235 times
José Araújo
Post by José Araújo » Thu Aug 12, 2010 1:57 pm
In transparency in SERIES I´d found problems too
Post by Yeray » Fri Aug 13, 2010 10:39 am
Hi Fausto,
Fausto Jr. wrote:I my example you should use the ROTATE TOOL and you can see the memory usage UP and UP UP UP UP.
So it's with most probability related with the problem discussed here and here (TV52014993). It has been already fixed for the next maintenance release.
I could reproduce the problem with the latest published version but with the actual sources it seems to work fine.
Fausto Jr. wrote:In transparency in SERIES I´d found problems too
Could you please explain us how can we reproduce it?
José Araújo
Post by José Araújo » Fri Aug 13, 2010 12:29 pm
When the next release will be available? I nedd this urgently.
Here the problem has been reproduced with the code:
uses
Series, TeeGDIPlus;
var
TBarSeries(Chart1.Series[0]).Transparency := 50; // THIS LINE INVOKE MEMORY LEAK (USE ROTATE TOOL TO SEE MEMORY USAGE UP UP...)
FGDIPlus.Active:=true;
properties of the release
FileTeeChart2010SourceCode PROPERTIES.JPG (27.22 KiB) Viewed 7596 times
Post by Yeray » Fri Aug 13, 2010 4:31 pm
Hi Fausto,
As you are source code customer, I've sent the actual sources to the mail you have registered in this forums.
Could you please check if they correct the problem?
José Araújo
Post by José Araújo » Fri Aug 13, 2010 5:11 pm
Could you re-send me the email? I changed my email because the older was written wrong.
Apologies!!!
Post by Yeray » Fri Aug 13, 2010 5:31 pm
Hi Fausto,
Just done!
José Araújo
Post by José Araújo » Mon Aug 16, 2010 12:19 pm
Yeray,
Thanks a lot buddy. Now, it's stable. And my boss is very happy. ;)
Thankful,
Fausto Jr.
Post by Yeray » Mon Aug 16, 2010 1:02 pm
Hi Fausto,
I'm glad to hear it! :D
Boas tardes!
