Waveform
PoLabs
Waveform
Post by PoLabs » Thu Aug 05, 2010 3:19 pm
I am using TChart and TFastLineSeries. I usually show up to 1024 data on chart. But I have in memory up to 8MB of data. I disabled ShowAllPoints but then idea about waveform type of display crossed my mine. I would like to show that 8MB of data at same time. If I do that computer performances drops which is logical. So Idea is to show 1024 points from that 8MB but in a way like waveform in musical programs is displayed.
Like here: Image
1. Is there any tool for TeeChart to do that. I was thinking about region tool?
2. What if I take two series (on inverted regarding other) is it possible to paint between that two series to recreate effect of waveform?
Best regards.
Re: Waveform
Post by Yeray » Fri Aug 06, 2010 1:23 pm
Hi Polabs,
If you can draw it in four series, it wouldn't be difficult to use, as you say, TSeriesBandTool:
uses Series, TeeSeriesBandTool;
var i, j: Integer;
  Chart1.View3D:=false;
  for i:=0 to 3 do
    with Chart1.AddSeries(TLineSeries) do
      Add(i*100);
      for j:=1 to 499 do
        Add(YValue[j-1] + Random -0.5);
  with Chart1.Tools.Add(TSeriesBandTool) as TSeriesBandTool do
    Series:=Chart1[0];
    Series2:=Chart1[3];
    Brush.BackColor:=RGB(77, 61, 220);
    Series.Color:=Brush.BackColor;
    Series2.Color:=Brush.BackColor;
    Series:=Chart1[1];
    Series2:=Chart1[2];
    Brush.BackColor:=RGB(150, 150, 237);
PoLabs
Re: Waveform
Post by PoLabs » Fri Aug 06, 2010 2:30 pm
Yes this is what I am looking for.
Thank you very much! Your support ROCKS! :wink:
