ChartGrid multiline heading?
Track1
Post by Track1 » Thu Jul 22, 2010 7:18 am
Is it possible to add multiple lines to a ChartGrid top line. I want to add more information about the series on say 3 lines of data.
If I use #13#10 (or #13) in the title string for the Series.Title it doesn't place multiple lines on the grid, but shows on continuous one line.
I have set the row height to be suitable to accommodate multiple lines.
How can I change the ChartGrid top line for each series and add multiple lines of text for each series added?
Many thanks
Trevor
Track1
Re: ChartGrid multiline heading?
Post by Track1 » Thu Jul 22, 2010 7:24 am
This is what I would like over 3 lines instead of one
22-07-2010 5-22-25 PM.png (3.45 KiB) Viewed 5250 times
Post by Yeray » Mon Jul 26, 2010 10:41 am
Hi Trevor,
I cound reproduce it.
I've seen that a workaround for the TCustomDrawGrid is to use OnDrawCell event as in the example bellow. But this event is defined in TCustomDrawGrid and this class inherits from TCustomGrid, and TChartGrid inherits from TCustomGrid too, so this event isn't defined.
I've added it to the wish list to be enhanced in future releases (TV52015047).
procedure TForm1.StringGrid1DrawCell(Sender: TObject; Col, Row: Longint; Rect: TRect; State: TGridDrawState);
var
   Line1: string;
   Line2: string;
   ptr: integer;
   padding: integer;
   hGrid: TStringGrid;
  hGrid:= (Sender as TStringGrid);
  ptr := Pos(';', hGrid.Cells[Col, Row]);
  if ptr > 0 then
     Line1 := Copy(hGrid.Cells[Col, Row], 1, ptr - 1);
     Line2 := Copy(hGrid.Cells[Col, Row], ptr + 1, Length(hGrid1.Cells[Col,Row]) - ptr);
  end
  else Line1 := hGrid.Cells[Col, Row];
  hGrid.Canvas.FillRect(Rect);
  hGrid.Canvas.TextOut(Rect.Left, Rect.Top + 2, Line1);
  if ptr > 0 then
     hGrid.Canvas.TextOut(Rect.Left, Rect.Top - hGrid.Canvas.Font.Height + 3, Line2);
