extra vertical grid line
superman007
Post by superman007 » Fri Mar 19, 2010 1:42 pm
I attach an image of a section of my chart.
As you can see, the TPointSeries draws an extra unwanted vertical grid line and the corresponding x-axis text that looks messy. How do I stop it from drawing the vertical grid line as well as adding the axis text?
Re: extra vertical grid line
Post by Yeray » Fri Mar 19, 2010 2:26 pm
Hi superman007,
You could hide the bottom axis:
  Chart1.Axes.Bottom.Visible:=false;
Or you could hide the grid lines and the labels separately:
  Chart1.Axes.Bottom.Grid.Visible:=false;
  Chart1.Axes.Bottom.Labels:=false;
superman007
Post by superman007 » Fri Mar 19, 2010 2:59 pm
That will get rid of all the grid lines. I don't want that. I want to only get rid of the grid line that is drawn for the TPointSeries (the "extra" grid line that you can see in the image that goes through the green arrow).
Post by Narcís » Fri Mar 19, 2010 3:46 pm
Hi superman007,
To be able to provide an accurate answer, could you please attach a simple example project we can run "as-is" to reproduce the problem here?
superman007
Post by superman007 » Mon Mar 22, 2010 10:07 am
I have fixed the issue by putting in a blank label into the AddXY function call.
Post by Yeray » Mon Mar 22, 2010 12:08 pm
Hi superman007,
Ah, I think I've understood what you wanted to do do. You only want to hide the label drawn at the TPointSeries.
I'm grad to see you've found the solution!
