Print Exception
bill.tarlinton
Print Exception
Post by bill.tarlinton » Tue Feb 09, 2010 3:08 am
Currently, I try to update teeChart from version 7 to version 8 for one of the products of my company.
When I print the chart using the printer "hp-laserjet-2840", it works fine.
When I print the chart using the printer "HP Color Laser Jet 2600n", It crashed with the exception "Floating point overflow".
I did test version 7. Version 7 works fine for both printers.
Then I wrote a small application to test this issue. Same thing again.
Attached is the small application I mentioned before. Could you give me some suggestions to solve this problem?
To regenerate the bug:
-run the attached application
-Press addSeries Button
-Press addPoints Button
-Press ShowMarks Button
-Press Print Button
On TeeChart Print Preview
-Press Print Button again. ->> Exception
Lizhi
Source.zip
(31.91 KiB) Downloaded 256 times
Re: Print Exception
Post by Narcís » Tue Feb 09, 2010 10:03 am
Hi Lizhi,
Yes, this is a known issue with Windows and some printer drivers. The issue was discussed here and the best solution is what dka suggested.
Hope this helps!
bill.tarlinton
Re: Print Exception
Post by bill.tarlinton » Wed Feb 10, 2010 3:41 am
Hi Narcís,
That works. Cheers
Lizhi
