Is it at all possible, to toggle the chart between Horizontal Bar, and Bar, with the same data, but differently orientated, according to user preference.
If possible, how do I achieve this in code?
I want to rotate this from HorizontalBar to Bar.
Switch programatically between HorizontalBar, and Bar
- horbarfixed.jpg (57.76 KiB) Viewed 6342 times
Re: Switch programatically between HorizontalBar, and Bar
Hi Doogie,
Yes, you could use ChangeSeriesType function. For example:
var i: Integer;
tmp: TChartSeries;
tmp:=Chart1[i];
if Chart1[i] is THorizBarSeries then ChangeSeriesType(tmp,TBarSeries)
else ChangeSeriesType(tmp,THorizBarSeries);
