SeriesGroups not reacting at Runtime
Doogie
Post by Doogie » Mon Nov 02, 2009 7:36 pm
I drop a DBchart on a form.
I then Add 20 series.
I add two Seriesgroups, and assign the series 10 to each seriesgroup.
Each series points to its respective datasource.
I then tick one of the two seriesgroups, and the chart then displays correctly at runtime.
Now I try to change the active seriesgroup at runtime, without any effect:
With DBChartBlup do
SeriesGroups.Items[0].Active:=TSeriesGroupActive(1);
SeriesGroups.Items[1].Active:=TSeriesGroupActive(0);
RefreshData;
No matter what I do:
SeriesGroups.Items[0].Active:=TSeriesGroupActive(0);
or
SeriesGroups.Items[1].Active:=TSeriesGroupActive(1);
seriesgroups remain at what they where set to in the IDE.
So, how do I achieve this at runtime, without having to set up all the series, and seriesgroups etc at runtime.
Adrian
Re: SeriesGroups not reacting at Runtime
Post by Yeray » Tue Nov 03, 2009 9:25 am
Hi Adrian,
I've taken the code from the demo at All features\Welcome !\Miscellaneous\Series\Series Goups to test it and everything seems to work as expected. What TeeChart exact version are you using?
uses series;
var  Group1, Group2 : TSeriesGroup;
var t : Integer;
    Line : TChartSeries;
 for t:=0 to 9 do
    Line:=Chart1.AddSeries(TLineSeries);
    Line.Title:='Line '+IntToStr(t);
    Line.FillSampleValues;
  // Create two "Series Groups", and add some series to each group...
  Group1:=Chart1.SeriesList.AddGroup('First group');
  Group1.Add( Chart1[0] );
  Group1.Add( Chart1[2] );
  Group1.Add( Chart1[4] );
  Group1.Add( Chart1[6] );
  Group1.Add( Chart1[8] );
  Group2:=Chart1.SeriesList.AddGroup('Second group');
  Group2.Add( Chart1[1] );
  Group2.Add( Chart1[3] );
  Group2.Add( Chart1[5] );
  Group2.Add( Chart1[7] );
  Group2.Add( Chart1[9] );
  // Show all series in first group
  Chart1.SeriesList.Groups[0].Show;
  // Hide all series in second group
  Chart1.SeriesList.Groups[1].Hide;
  With Chart1.SeriesGroups do
    if Items[0].Active = gaYes then
      Items[0].Active:=gaNo;
      Items[1].Active:=gaYes;
    end
      Items[0].Active:=gaYes;
      Items[1].Active:=gaNo;
Doogie
Post by Doogie » Wed Nov 04, 2009 8:19 pm
V8.02.10861
Also note, that I don't want to build the series groups at runtime, but use them as set up in the IDE.
Adrian
Post by Yeray » Thu Nov 05, 2009 11:08 am
Hi Adrian,
I've found that at design time adding a series to a group is listed fine but the group doesn't seem to really contain the series:
  Showmessage(inttostr(Chart1.SeriesGroups.Items[0].Series.Count));
On the other hand, having a group created at design time, you can add series at runtime:
procedure TForm1.Button2Click(Sender: TObject);
  with Chart1.SeriesGroups.Items[0] do //group created at design time
    Add( Chart1[0] );
    Add( Chart1[2] );
I've added this to the wish list to be fixed in future releases (TV52014535). In the meanwhile I recommend you to add the series to the groups at runtime if possible.
