we got charts with much series. When we scroll or zoom the chart everything is very slow. I tried to use another canvas like GDI and GDI+. It can't be the machine. I try it on a new notebook that's less then four months old (2.6GHz Core 2 Duo, 4GB Ram, ATI Radeon 3650 512MB). This doesn't help. Do you know any tricks to get better performance with a lot of series/data?
TeeChart 7.08 on BDS2006 (Delphi)
I've attached a tee file with much series and data. It looks very overloaded but that's correct (it's a non filtered selection of data).
Performance problems with much series
- performance.zip
- TeeChart file with lots of series and data
- (177.86 KiB) Downloaded 255 times
Re: Performance problems with much series
Hi Tom
It would be more helpful a tee file saved as text to allow us to see how was it exactly set:
On the other hand, could you please tell us what exactly TeeChart version are you using?
Anyway, please, take a look at the Real-time Charting article. There are some tips you could use to improve your chart performance.
SaveChartToFile(Chart1,'c:\tmp\performance.tee',True);
DoneYeray wrote:It would be more helpful a tee file saved as text
I wrote thatYeray wrote:On the other hand, could you please tell us what exactly TeeChart version are you using?
I will do that.Yeray wrote:Anyway, please, take a look at the Real-time Charting article. There are some tips you could use to improve your chart performance.
I just took a look at the documentation. I was looking if I can use TFastLineSeries instead of TLineSeries but I can't
Hi CTgmbh,
Thank you.CTgmbh wrote:DoneYeray wrote:It would be more helpful a tee file saved as text
Oups, Excuse me.CTgmbh wrote:I wrote thatYeray wrote:On the other hand, could you please tell us what exactly TeeChart version are you using?It's TeeChart 7.08 on BDS2006 (Delphi)
If you find any problem with it, please, don't hesitate to let us know.CTgmbh wrote:I will do that.Yeray wrote:Anyway, please, take a look at the Real-time Charting article. There are some tips you could use to improve your chart performance.
I'm not sure to understand why you can't use Fast Lines instead of Lines. Your lines don't have pointers visible, your chart isn't in 3D,...CTgmbh wrote:I just took a look at the documentation. I was looking if I can use TFastLineSeries instead of TLineSeries but I can't
