Radar Chart issue with Let Axis Minimum
RPABECH
Post by RPABECH » Tue Jun 23, 2009 11:39 am
For some reason my Radar Chart do not update the Left Axis minimum value. I wand to set the minimum value to (-1/3) of the Maximum Scale.
Ex: if MAx Scale = 900 the Minimum should be -300.
But when I run my project and click the button, it does not work at first. I can go to ythe chart editor and see that the Axis are -0.33 of the Max scale, but for some reason the chart do not update the Minimum Left Axis. IF I click the Button again, then it works. What I am doing wrong?
This is my code (using Delphi 7 and TeeChart 8):
populate_radar(Series1,Series2,'1');
Chart1.Axes.Left.AutomaticMinimum:=false;
Chart1.Axes.Left.Minimum:=Chart1.Axes.Left.Maximum * (-0.33);
procedure populate_radar(S1,S2:TRadarSeries;RadarIndex: string);
var
i:integer;
  S1.Clear;
  S2.Clear;
  for i:= 0 to 30 do
  S1.AddXY(i*12,1 + Random(900),'Port ' + inttostr(i));
  S1.ClockWiseLabels:=true;
  for i:= 0 to 30 do
  S2.AddXY(i*12,1 + Random(800),'Port ' + inttostr(i));
  S2.ClockWiseLabels:=true;
Ricardo abech
Re: Radar Chart issue with Let Axis Minimum
Post by Yeray » Tue Jun 23, 2009 2:02 pm
Hi Ricardo,
Try forcing the chart to be repainted after the points generation. This will update the left axis maximum value and the calculation to obtain the minimum should be fine:
Chart1.Repaint;
RPABECH
Post by RPABECH » Tue Jun 23, 2009 3:56 pm
I added the Chart1.Repaint but still no luck. Can you reproduce the issue?
Ricardo
Post by Yeray » Thu Jun 25, 2009 7:41 am
Hi Ricardo,
I reproduced the issue and Chart1.Repaint call solved it for me here. Here is the full code I use:
unit Unit1;
interface
uses
  Dialogs, TeeComma, ExtCtrls, TeeProcs, TeEngine, Chart, Series, TeePolar,
  StdCtrls;
type
  TForm1 = class(TForm)
    TeeCommander1: TTeeCommander;
    Button1: TButton;
    Chart1: TChart;
    Series1: TRadarSeries;
    Series2: TRadarSeries;
  private
    { Private declarations }
  public
    { Public declarations }
var
  Form1: TForm1;
implementation
{$R *.dfm}
var i:integer;
  S1.Clear;
  S2.Clear;
  for i:= 0 to 30 do
  for i:= 0 to 30 do
  Chart1.Repaint;
end.
If you still can't see the issue solved, please, could you please try to send us the simple project where you can reproduce it?
RPABECH
Post by RPABECH » Thu Jun 25, 2009 12:02 pm
Hey ... That solved the problem. I was using the Repaint in the end instead of between the Axis change.
Thanks!
Best regards,
Ricardo Abech
RPABECH
Post by RPABECH » Thu Jun 25, 2009 1:03 pm
A new problem. When I use the Anti-Alias in my Radar PLot, for some reason the PEN of my RadarSeries becomes Black.
I would like to keep the currnt color of the Pen.
Ricarod Abech
Post by Yeray » Thu Jun 25, 2009 3:32 pm
Hi Ricardo,
I've added the following code to the previous and everything seems to work as expected:
uses TeeAntiAlias;
  Chart1.Tools.Add(TAntiAliasTool.Create(self));
RPABECH
Post by RPABECH » Thu Jun 25, 2009 3:54 pm
HI,
Yes, the Anti-Alias works. But my Pen Color gets changed to Black for all series. I really need them to keep their colors.
See attached file.
Best regards,
Ricardo Abech
Post by Yeray » Fri Jun 26, 2009 9:19 am
Hi Ricardo,
I've tried to reproduce your problem again and couldn't. Here is the code I use to create a chart similar to yours:
uses TeeAntiAlias, Series, TeePolar;
var i:integer;
  S1.Clear;
  S2.Clear;
  for i:= 0 to 30 do
  for i:= 0 to 30 do
var series1, series2: TRadarSeries;
  Chart1.View3D := false;
  Chart1.Color := clWhite;
  series1 := TRadarSeries.Create(self);
  series2 := TRadarSeries.Create(self);
  Chart1.AddSeries(series1);
  Chart1.AddSeries(series2);
  series1.Color := clBlue;
  series1.Pointer.VertSize := 2;
  series1.Pointer.HorizSize := 2;
  series1.Brush.Style := bsSolid;
  series1.Transparency := 50;
  series2.Color := clYellow;
  series2.Pointer.VertSize := 2;
  series2.Pointer.HorizSize := 2;
  series2.Brush.Style := bsSolid;
  series2.Transparency := 50;
  populate_radar(series1, series2,'1');
  Chart1.Repaint;
Please, modify the code above or simplify your code til get a code as simple as possible we can run as-is here to reproduce the problem here.
Post by Yeray » Fri Jun 26, 2009 9:29 am
Hi Ricardo,
Now I could reproduce it. The problem seems to be with the combination AntiAlias Tool + Rose Series Pen Width greater than 1. I've added it to the wish list to be fixed in future releases (TV52014265).
  Chart1.AddSeries(TRadarSeries.Create(self));
  Chart1[0].FillSampleValues(10);
  Chart1[0].Pen.Width := 2;
RPABECH
Post by RPABECH » Fri Jun 26, 2009 12:08 pm
Yes. That works fine for PEN Width = 1. But if I increase that to 2 or more (I use 3), then The pen turns Black.
Do you see this same behaviour?
Ricardo Abech
Post by Yeray » Fri Jun 26, 2009 1:27 pm
Hi Ricardo,
Yes, that's the bug I've added to the list.
