Different gradient colors for different slices
Tom
Post by Tom » Mon Apr 06, 2009 10:31 am
Is it possible to have a different gradient color for different slices?
For example: a pie chart with 3 slices:
slice 1: 30% red gradient,
slice 2: 50% green gradient,
slice 3: 20% orange gradient
also, is this possible with donuts?
another solution might be to have a third dimension for each slice.
Post by Yeray » Mon Apr 06, 2009 2:02 pm
Hi Tom,
I'm afraid that it wouldn't be easy to define custom gradients for each slice. But it would be easy if you could start with a shared color, white for example:
uses Series, TeCanvas;
var pie1: TPieSeries;
  pie1 := TPieSeries.Create(nil);
  Chart1.AddSeries(pie1);
  pie1.Add(30,'',clRed);
  pie1.Add(50,'',clGreen);
  pie1.Add(20,'',RGB(255,128,64));
  pie1.Gradient.Visible := true;
  pie1.Gradient.StartColor := clWhite;
  pie1.Gradient.Balance := 100;
  pie1.Gradient.Direction := gdFromBottomLeft;
