Trend lines - 2 question
Shimon
Post by Shimon » Wed Mar 04, 2009 10:37 am
I have uploaded 2 images (upload page) to make things clear - ShimonSoferTrendQ1.png, ShimonSoferTrendQ2.png .
My questions
1. In the first image (not all points are displayed) I see the the slope makes sense but the height of the line has certain offset... I also noticed that this y-offset is changing significantly when new points are inserted to the series...
The code I am using is -
MA := TTrendFunction.Create(Self);
MA.Period := 0;
With Self do // Self is the Tee Chart itself...
tmpHighLine:=TLineSeries.Create(self);
tmpHighLine.XValues.DateTime:=True;
tmpHighLine.Color := clRed;
tmpHighLine.VertAxis := aRightAxis;
AddSeries(tmpHighLine);
//Define the Function Type for the new Series
tmpHighLine.SetFunction(MA);
tmpHighLine.DataSource := FLineSeries
2. In the second image you can see that I am using a Period which is different from 0 (actually 20). Again you can see the y-offset of the line from the points but another issue bother me : The many trend lines are connected to each other... I would like the lines to be separated...
Shimon
Post by Yeray » Thu Mar 05, 2009 9:48 am
Hi Shimon,
1. You say that you are not displaying all the points, so you are controlling your bottom axis manually, aren't you? If you aren't controlling also manually the left axis and you want to do it, consider using the function commented here
2. To draw a uncontinuous line, you could add some null points. IO think you could do something similar to the demo at What's New?/Welcome/New in Series/FastLine TreatNulls
Shimon
Post by Shimon » Thu Mar 05, 2009 9:54 am
Thank you for your answers.
1. I am displaying all points - the screen shot I have sent you doesn't contain all the region - that what I meant.
So I still dont have solution for the height offset. Even when I checked the calculation without the display (by looking at the points coordinates in a log file) I saw the the "y" offset of the line I talked about.
2. Thanks about the null values - I'll check that.
Post by Yeray » Thu Mar 05, 2009 3:42 pm
Hi Shimon,
I'm not sure to understand what is your exact problem. Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
