Not getting all the Data points to show on the Graph
lkuderick
Post by lkuderick » Tue Feb 24, 2009 1:01 pm
I'm using TeeChart Pro 7.0 w/Delphi 2006
I'm working with a Line Series graph and my problem is that I'm only getting a display of what looks to be 256 of the 512 points that I am sending to my graph to show.
I have two x and y arrays of double, both contain 512 points. I've added a stringgrid to show that all the points are being added to the graph using the code below. However, the data points stop plotting at roughly 1/2 the array (which I'm guessing is 256).
Using the following code:
       for i := 0 to 511 do
        x := xVal[i];
        y := yVal[i];
        AddXY(xVal[i],yVal[i]);
        if (SeriesIndex = 0) and (chart.Name = 'DisplayChart') then
         Mainform.ChartGrid1.Cells[0,i-fc] := Format('%.3f',[x]);
         Mainform.ChartGrid1.Cells[1,i-fc] := Format('%.3f',[y]);
Any ideas? I've been trying to work around this for a couple of days and I'm totally stumped.
lkuderick
Post by lkuderick » Tue Feb 24, 2009 2:15 pm
Okay, I figured out my problem - I was doing it to myself. I had a procedure that was truncating my array. After I fixed it, everything was good.
Post by Yeray » Tue Feb 24, 2009 2:24 pm
Hi lkuderick,
I'm happy to see that you found your problem.
