Transparent Background
GreenHorn
Post by GreenHorn » Sat Oct 04, 2008 10:02 am
Hello all,
is this possible, to set the background of tChart (V8) transparent?
So the Chart will fit in the form with the same appearence.
kind regards
Greeny
Post by Narcís » Mon Oct 06, 2008 8:04 am
Hi Greeny,
Yes, this is possible. I've sent you an example project on how to do that.
GreenHorn
Post by GreenHorn » Sat Oct 25, 2008 7:33 am
thank you Narcís,
I've got it.
kind regards
greeny
Jørgen
Post by Jørgen » Tue Mar 03, 2009 3:30 pm
Could you send this to me as well?
Thanks Jørgen
Post by Narcís » Tue Mar 03, 2009 3:47 pm
Hi Jørgen,
Yes, just sent the project.
dave555
Re: Transparent Background
Post by dave555 » Wed Jul 29, 2009 8:51 pm
Hello Narcis
Could I please also be sent the example of a transparent chart background. thanks
Post by Narcís » Thu Jul 30, 2009 9:14 am
Hi dave555,
Yes, of course. Just sent it to your forums profile e-mail.
dave555
Post by dave555 » Thu Jul 30, 2009 3:41 pm
Hello Narcis
Thank you for sending me the project. When I run it, I get the result shown in the attached image - definitely not showing a map series with transparent chart background. I am using Delphi 2009 with Vista. Any help would be appreciated.
David
Post by Yeray » Fri Jul 31, 2009 8:49 am
Hi David,
I'm not sure to understand what you mean. I see a map series, and I see the image behind the chart. Could you please explain what you are exactly trying to achieve?
On the other hand, as this new forum allows us to attach files, here is the project for whoever wants it.
TranspChart.zip
Transparent chart example
(1.85 MiB) Downloaded 1303 times
dave555
Post by dave555 » Sat Aug 01, 2009 1:51 pm
Hi Narcis
You are quite right; the demo project does work correctly.
I am saving files in PNG, TIFF and GIF formats. My hope is that in those saved images the chart background could be transparent.
David
Post by Yeray » Mon Aug 03, 2009 8:45 am
Hi David,
I'm afraid that exporting to bitmaps charts with transparency is a known problem already in the wish list to be fixed in further releases.
