MultiSeries Question
Miroslav Hometa
Post by Miroslav Hometa » Thu Aug 28, 2008 7:48 am
Hello!
I have an problem:
I have two TBarSeries (mbSide). 2D is set.
Now I want to insert on every Bar-side 2 different series
(PointSeries and ErrorSeries) which will overlay the bars.
Is this possible and how can I do this!
I have posted an image on your upload page to visualize
how this should look! (3S-mbSide.JPG)
With best regards
Post by Pep » Fri Aug 29, 2008 4:33 pm
Hi Miroslav,
it's possible to do it, but using some tricks. For example you should use an extra axis (custom horizontal axis) for each series you wanto to display over each Bar Series. Setting each Point Series horiz axis to the custom one and then assign a minimum offset to it (to move the Series) should do the trick.
