min / max areas
msd48
min / max areas
Post by msd48 » Tue Aug 19, 2008 6:25 am
Hi!
I attempt to draw this graph:
type
  TForm1 = class(TForm)
    DBChart1: TDBChart;
    Series1: TFastLineSeries;
  private
    { Private declarations }
  public
    { Public declarations }
There is min and max of value in graph.
It is necessary to make the filling of that region of graph, which leaves in max or min...
How I can do this?
Thanks for your answers.
Post by Yeray » Tue Aug 19, 2008 9:29 am
Hi msd48,
I think that with the ClipSeries tool you should achieve what you want.
msd48
Post by msd48 » Tue Aug 19, 2008 11:54 am
Hi Yeray!
How does this tool work?
I dont find an example in Tee8New.exe...
Moreover there is no options in this tool, besides the selection of a series…
Can you help me?
Post by Yeray » Wed Aug 20, 2008 9:14 am
Hi msd48,
Here is a simple example of what it does. Add a Chart and a checkbox into a new form. Then add a line series and a ClipSeries tool into the chart. And the code:
procedure TForm1.CheckBox1Click(Sender: TObject);
  ChartTool1.Active := CheckBox1.Checked;
  Series1.FillSampleValues(25);
  ChartTool1.Series := Series1;
  with Chart1.Axes.Bottom do
    StartPosition := 20;
    EndPosition := 80;
    SetMinMax(2,8);
msd48
Post by msd48 » Fri Aug 22, 2008 11:42 am
Thanks for help.
Question is closed.
