Monochrome Points
Andy
Monochrome Points
Post by Andy » Mon Feb 04, 2008 10:53 am
Hello !
I found a problem when I print a chart to a monochrome printer.
This problem occurs in a monochrome chart on screen, too.
All points in a lineseries are filled with white color
(real white not background) independet which color is set!
The only way to print points in monochrome I found is to set its gradient.
Is this a bug or a feature :-)
Best regards
Andreas
Post by Pep » Fri Feb 08, 2008 5:41 pm
Hi Andreas,
maybe you're trying to get the Chart in grayScale mode ?
If so, you can use the following code :
uses TeCanvas, TeeFilters;
     TeeGrayScale( (Chart1.Canvas as TTeeCanvas3D).Bitmap,
                    false, 0);
Andy
Post by Andy » Mon Feb 11, 2008 9:40 am
Pep wrote:Hi Andreas,
                    false, 0);
Fine ! That is what I wanted. :lol:
Thank you for the tip.
