ZValue on TContourSeries
Werner
Post by Werner » Thu Dec 06, 2007 4:28 pm
I use Teechart V8.02. AT my Tchart I have added a TContourSeries and a TCursorTool assigned to that series.
With the event
ChartTool1Change(Sender: TCursorTool; x, y: Integer;
const XValue, YValue: Double; Series: TChartSeries; ValueIndex: Integer);
I want to show x,y and z value. XValue and YValue are provided with this event, but how can I get the Z-Value ?
ValueIndex is alwas -1.
The function (Series as TContourSeries).GetCursorValueIndex returns only the LevelIndex.
Locate returns also -1.
What can I do ?
Best regards
Werner
Post by Narcís » Fri Dec 07, 2007 10:01 am
Hi Werner,
This is a bug (TV52012626) which I've added to our defect list to be fixed for future releases.
In the meantime you can use OnMouseMove event like this:
procedure TForm1.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
  Y: Integer);
var index: Integer;
  index:=Series1.Clicked(X,Y);
  if index<>-1 then
    Caption:=FloatToStr(Series1.XValues[index]) + ', ' +
              FloatToStr(Series1.YValues[index]) + ', ' +
              FloatToStr(Series1.ZValues[index]);
Werner
Post by Werner » Fri Dec 07, 2007 10:56 am
Dear Narzis,
thank you for your help, but this doesn't work. The index is always the level and not the index of the array.
Any other suggestion ?
with best regards
Werner
Post by Pep » Mon Dec 10, 2007 4:53 pm
Hi Werner,
are you creatinga 2D or 3D Contour Chart ?
Werner
Post by Werner » Mon Dec 10, 2007 5:10 pm
Hi Pep,
I use the TContourSeries wich 3D unchecked, so the view is 2D.
best regards
Werner
