TDBChart summary null values
Thomas Klingler
Post by Thomas Klingler » Fri Nov 02, 2007 1:20 pm
When I use a DBchart with the summary avg function on a field, null values are taken in the computation yielding false results.
Is there a way to ignore null values?
TIA
Markus
Teechart 7.12
Post by Narcís » Mon Nov 05, 2007 8:14 am
Hi Markus,
Yes, you can set IncludeNulls property to false as shown in the All Features\Welcome!\Functions\Standard\Average\Average and nulls example in the features demo, available at TeeChart's program group.
Thomas Klingler
Post by Thomas Klingler » Mon Nov 05, 2007 12:04 pm
Hi Narcís,
thanks for your reply, but this is not what I was looking for. Rereading my question I have to admit that it was not quite clear. So here again my problem:
I use a DBChart with a Clientdataset as the value source. If I choose summary from the dropdown menu I can select different summaries from the dropdown menu in the editor (sum, count, high, low, avg). When I choose avg of one field grouped by another field, then NULL values go into that computation leading to false results. Hence my question if I can tell the series to ignore NULL values when computing the average.
Markus
Post by Pep » Fri Nov 09, 2007 11:48 am
Hi Markus,
yes, this feature has not been yet implemented, it's on our wish list as a feature request to be considered for further releases.
In meantime the only workaround I can think of would be to calculate the summaries manually.
