ZOOM
altran
ZOOM
Post by altran » Fri Sep 28, 2007 12:18 pm
When I start the Chart Editor screen and I close it, The zoom is automatically actived, could you help me to solve this problem ?
Thank you.
Wil.
Post by Narcís » Fri Sep 28, 2007 1:24 pm
Hi Wil,
Which exact TeeChart version are you using? Could you please send us a simple example project we can run "as-is" or let us know the steps we should follow to reproduce the problem here?
You can either post your files at news://www.steema.net/steema.public.attachments or at our upload page.
Thanks in advance!
altran
Post by altran » Fri Sep 28, 2007 1:31 pm
I use the 7.08 for Delphi 2006. I have create a procedure on the double click event of my teexhart with this code :
procedure TfrmMainAnalyseHydro.chartAnalyseHydroLEELEPDblClick(Sender: TObject);
editChart(self, TCustomChart(sender));
When I double clik on the teechart, the editor appear but when I close it, the zoom function with the dots appear on the teechart. At this moment, I must zoom two times on the teechart to come back on a normal state.
I have started a demo and I don't reproduce the problem.
I hope it's clear for you ;)
Thanks a lot.
Wil
Post by Pep » Mon Oct 01, 2007 12:03 pm
Hi Wil,
to solve it you can do :
procedure TForm1.Chart1DblClick(Sender: TObject);
 Abort;
altran
Post by altran » Mon Oct 01, 2007 12:35 pm
Thanks a lot for the help ;).
Wil
xxxxxx
Post by xxxxxx » Mon Oct 01, 2007 3:58 pm
Hi, Pep!
So far in such cases I used something like that
TCustomChart(sender)).CancelMouse
Do you reccomend use Abort procedure instead that actually invokes sort of exception?
Regards, Alexander
TeeChart Pro v8.05, Delphi 5 & Turbo Delphi Professional for Win32., Delphi & C++Builder 2009
Post by Pep » Mon Oct 08, 2007 9:33 am
Hi Alexander,
CancelMouse can be used too, it should work in similar way, it stops or not the events calls in mouse click events.
Abort wont allow you to choose if they must be fired or not, just abort them.
