TeeInspector, Selections
Paul
Post by Paul » Fri Jul 06, 2007 6:24 pm
Can anyone direct me to some example code on how to set up a Selection in the TeeInspector component?
Paul
Post by Narcís » Fri Jul 06, 2007 8:05 pm
Hi Paul,
Have you seen the example at All Features\Welcome!\Components\Inspector component in the features demo? You'll find the features demo at TeeChart's program group created by the binary installers. Source code installer doesn't include any example nor documentation.
Paul
Post by Paul » Fri Jul 06, 2007 8:51 pm
Narcis -
Maybe I should have mentioned that I've already checked the features demo. Unfortunately, the demo code does not include implementation of a Selection. Is there someplace else I can look?
Paul
Paul
Using TeeInspector, creating items at runtime
Post by Paul » Thu Jul 12, 2007 2:14 pm
Can anyone help with information on using TeeInspector? The example code on "all features" gives no hints for programming with this component. I need to create items at run time, as well as populate the selections.
Paul
Post by Pep » Fri Jul 13, 2007 9:17 am
Hi Paul,
I think the better example code to check and review which could help you is the TeeChartOffice demo sources, it uses most of the characteristics of TeeInspector.
Paul
Post by Paul » Fri Jul 13, 2007 1:50 pm
Thanks - but unfortunately that code doesn't help much either as far as setting up items at run time. All it does is:
Inspector.SetProperties(DBChart1.PopupMenu);
I'm trying to set up properties indendant of any chart, and I don't have TeeInspector.pas which is where this method is located.
I've got some working by trial and error, but I'm sure I'm missing a lot.
Paul
Post by Pep » Mon Jul 16, 2007 6:38 am
Hi Paul,
ok, no worries. I'm not sure what you're trying to do but if you just want to add some options and check the selection you can use similar code to the following :
procedure TForm1.GetTestItems(Sender:TInspectorItem; Proc:TGetItemProc);
  Proc('One');
  Proc('Two');
  Proc('Three');
var Item : TInspectorItem;
  TeeInspector1.Clear;
  Item:=TeeInspector1.Items.Add(iiSelection,'Test',nil);
  Item.OnGetItems:=GetTestItems;
  Item.Value:='Two';
