teeSplitInLines
dmisland
teeSplitInLines
Post by dmisland » Wed Mar 07, 2007 9:39 am
I see reference to the TeeSplitInLines method in the TChart PRO v7 component library help (tchartaxis.Labelsmultiline), and also in this forum; however it is absent from the source code. Can you help?
Thanks, David
Post by Pep » Mon Mar 12, 2007 9:41 am
Hi David,
yes, you are correct. We forgot to add/change the info in the Help.
It has been changed by :
var s:string;
s:='abc'+TeeLineSeparator+'def';
result:=ReplaceChar(s,' ',TeeLineSeparator);
The ReplaceChart is in the TeeProcs.pas unit.
