3D Pie intersects with Chart title
MikeI
Post by MikeI » Fri Jan 19, 2007 2:19 am
Steps to reproduce are as follows:
1. In design mode create a chart and give it a title.
2. Add a single 3D pie series to the chart.
3. DblClk on the chart to pop the ChartEditor dialog and go to the 3D tab. 4. Set the 3D% spin control to 100%.
5. Now vary the Elevation slider and you will see the pie overlap the title at some point.
What can I do to avoid this?
Kevin
Post by Yeray » Fri Jan 19, 2007 8:56 am
Hi MikeI,
We could reproduce the problem here and we added it into our wish-list to be enhanced for future releases.
Also note that the problem only appears when you turn marks to not visible and your form has to be quite wider than high.
