thr4sh3r
Post
by thr4sh3r » Fri Aug 04, 2006 11:44 am
Who can help me? Narcis is away.
Ill need to show you quite a bit of code and explain what its doing.
Anyone up for it?
It to do with CloneTools, when i do this it doesnt keep the properties Snapstyle etc. I need it to keep these properties. The problem is, all my charts are created dynamically at runtime.
Justin
Post
by Pep » Mon Aug 07, 2006 9:11 am
Hi Justin,
are you using similar code to the following to clone the Chart tools ?
Function CloneChartTool(ATool:TTeeCustomTool; AOwner: TComponent):TTeeCustomTool;
result:=TTeeCustomToolClass(ATool.ClassType).Create(AOwner);
result.Assign(ATool);
var i: Integer;
Chart2.Tools.Clear;
Chart2.Assign(Chart1);
for i:=0 to Chart1.Tools.Count-1 do
CloneChartTool(Chart1.Tools[i],Chart2).ParentChart:=Chart2;
EditChart(Self,Chart2);
The above code might help you clone only chart tools. But you might have to add additional safeguards if for example a tool is connected to specific series and the destination chart doesn't have this series type.
thr4sh3r
Post
by thr4sh3r » Mon Aug 07, 2006 11:44 am
Yeah, that is exactly the problem.
The problem comes in because my charts are created dynamically by the user at runtime.
Any ideas on how to fix?
Post
by Pep » Mon Aug 07, 2006 1:26 pm
in that case, the only way around this that I know of would be to check which tool type must be copied and depending of the type check the properties which has not been copied and assign them manually.
thr4sh3r
Post
by thr4sh3r » Tue Aug 08, 2006 8:47 am
I did try this. I am not an idiot. But i cant get the properties to assign the properly to the Tool. Because of all the arrays and the dynamic creation of the charts.
Can you help me more specifically?
I can send you the code or something...
Post
by Narcís » Mon Aug 21, 2006 10:07 am
Hi thr4sh3r,
Please send us a project we can run "as-is" to reproduce the problem here at news://
www.steema.net/steema.public.attachments newsgroup.
