ChartPreviewer - change default Detail from Normal to More
SteveP
Post by SteveP » Mon Jun 19, 2006 8:32 pm
Is it possible to programmatically change the default ChartPreviewer Detail trackbar setting from Normal to More so the user sees an initial setting of More ?
Can the margins setting be changed from percent to pixels or better yet to inches ?
Also, can the default margins the programmatically set to say 5 % ?
Steve
Post by Narcís » Tue Jun 20, 2006 8:20 am
Hi Steve,
Yes, you can do this using:
  Chart1.PrintResolution := -100 ;
This is not possible for now, they are only be set in percent units. I'll add your request to our wish-list to be considered for future releases.
Yes, use:
  Chart1.PrintProportional := false;
  Chart1.PrintMargins:= Rect(5, 5, 5, 5);
SteveP
Post by SteveP » Wed Jun 21, 2006 3:38 pm
Thanks Narcis.
Can the printer orientation be changed from its landscape default to portrait ?
I am displaying the chart on the computer monitor with a black BackWall.Color but wish to print it with a white BackWall.Color. I could temporarily change the BackWall.Color to white and then call ChartPreviewer, but the user would then see that color change on their monitor. Additionally, other chart properties need to be changed when printed such as axis label font size increased. What is a recommeded approach to solve this ? I have created an invisible temporary chart at run time and Assigned it to the displayed chart. I can then change this temporary chart's properties as desired for printing.
However, my displayed chart has its axis labels customized in OnGetAxisLabel by changing that event's LabelText property. These changed labels do not persist into the temporary chart using the Assign method. Is there a way they can be ?
I also note that a cursor tool on the displayed chart shows up in the Chart Previewer.
Steve
SteveP
Post by SteveP » Thu Jun 22, 2006 2:50 am
Also, can the size of the printer paper on which the chart to be printed is displayed be increased so that it occupies more of the ChartPreviewer's panel (the gray to white gradient panel) ? It appears to be a fixed percentage. I'd like to make the chart appear larger to the user.
I've tried using ChartPreviewer1.PreviewPanel.MarginUnits := muPixels;
ChartPreviewer1.PreviewPanel.MarginLeft := 10;
but this had no effect.
Can the default ChartPreviewer window size be increased so the previewed chart would appear larger to the user ?
Some changes on the ChartPreviewer take 5 seconds or more for the previewed chart to update (printer orientation, smooth checkbox). Can some indication be given to the user that the program is actually processing (cursor change to hourglass for example).
Steve
Post by Pep » Mon Jun 26, 2006 11:05 am
Hi Steve,
The following code worked fine:
Uses TeePrevi,Printers;
{$R *.dfm}
  Series1.FillSampleValues(10);
  TeeChangePaperOrientation := False;
  Printer.Orientation := poPortrait;
  ChartPreviewer1.Execute;
BTW, I've set the TeePrevi.pas global variable TeeChangePaperOrientation to false to avoid resetting printer orientation to poLandscape in TChartPreview.FormShow routine.
How about usign the OnBeforePrint event ? Setting the modifications that you want to get :
procedure TForm1.Chart1BeforePrint(Sender: TCustomTeePanel;
  Canvas: TCanvas; var R: TRect);
Chart1.BackWall.Color:=clblue;
Yes, they are not copied as these has been changed once the Chart is displayed, the only way I can think of is to do the modif. in the new Chart.
Yes, this is by default, you will have to set Active to false when the ChartPreviewer is called :
  ChartTool1.Active:=false;
  Charttool1.Active:=true;
It cannot be changed in the existing version.
You can do :
  ChartPreviewer1.WindowState:=wsMaximized;
I'm afraid that there's not a way.
