where is OnChangeSelectedSeries event of TChartListBox
Fang
Post by Fang » Thu Apr 06, 2006 1:31 am
hi,
I couldn't figure out where can I capture event like OnChangeSelectedSeries and OnAddSeries at TChartListBox.
Fang
Post by Pep » Tue Apr 11, 2006 1:22 pm
you could use the OnOtherItemsChange and the OnRefresh events of the TChartListBox component.
procedure TForm1.ChartListBox1OtherItemsChange(Sender: TObject);
showmessage('Selected index changed');
procedure TForm1.ChartListBox1Refresh(Sender: TObject);
showmessage('check here which series has been added');
Fang
Post by Fang » Tue Apr 11, 2006 2:35 pm
Thanks pep.
BTW, the reason I need it is that I put the chartlistbox non-visible. I tried to replace the legend with the chartlistbox, but visually it's not good due to that highlighted selection so I hide it.
