Series Clicked and Marktip Text
McMClark
Post by McMClark » Tue Jan 03, 2006 5:01 pm
I am using TeeChart 7.05 with Delphi 2005 in a vcl application. I have a dbChart that I programmatically add multiple series based on a query. I have the tool MarkTip enabled in the dbChart. I want to be able to have my application detect what series the user clicks and the value of the MarkTip text at that time. Can anyone tell me how to do that?
Post by Pep » Thu Jan 05, 2006 9:54 am
this can be easily done using the MarksTipTool, setting Series to (all) and Mouse Action to "Click", and them use the following events :
procedure TForm1.ChartTool1GetText(Sender: TMarksTipTool;
  var Text: String);
label1.caption := ' MarkText: ' + text;
procedure TForm1.Chart1ClickSeries(Sender: TCustomChart;
  Series: TChartSeries; ValueIndex: Integer; Button: TMouseButton;
label2.caption := 'Series : ' + Series.Name;
McMClark
Post by McMClark » Thu Jan 26, 2006 6:21 pm
Thanks the Tooltip worked but the series name is not being passed. I made sure that the series have names. What could I be doing wrong?
Post by Narcís » Fri Jan 27, 2006 9:33 am
Hi McMClark,
You can try using Chart1[ValueIndex].Name or Chart1[ValueIndex].Title.
McMClark
Post by McMClark » Sat Feb 04, 2006 7:08 pm
I want to enable the MarkTipTool in DBCharts that I build at runtime. I want the tool tip to show the X value when the cursor passes over a point on the graph. How can I do that. The code I have is
var
DBChart1: TDBChart;
intList: integer;
for intlist := 1 to NumOfCharts Do
DBChart1 := TDBChart.Create(Self);
DBChart1. Top := LastChartTop + LastChartWidth + 10
DBChart1.Height := DefaultHeight;
tmpLineSeries := TLineSeries.Create(self);
DBChart1.AddSeries(tmpLineSeries);
With tmpLineSeries do
Begin
DataSource:= TempResults_Query1;
YValues.ValueSource := 'Score';
XLabelsSource := 'PublicationDate';
Pointer.Visible := False;
Title := strSubject;
CheckDataSource;
OnGetPointerStyle:=Series1GetPointerStyle;
Post by Narcís » Mon Feb 06, 2006 8:29 am
Hi McMClark,
Yes, you can add the following to your coee to achieve what you request:
  DBChart1[0].FillSampleValues();
  DBChart1.Tools.Add(TCursorTool.Create(self));
  (DBChart1.Tools.Items[0] as TCursorTool).FollowMouse:=true;
  (DBChart1.Tools.Items[0] as TCursorTool).OnChange:=ChartTool1Change;
  (DBChart1.Tools.Items[0] as TCursorTool).Style:=cssVertical;
procedure TForm1.ChartTool1Change(Sender: TCursorTool; x, y: Integer;
  const XValue, YValue: Double; Series: TChartSeries; ValueIndex: Integer);
  DBChart1.Title.Text[0]:='Cursor X Value: '+FloatToStr(XValue);
You'll also have to include TeeTools unit into your uses section.
