Intraweb v7.2 and TeeChart v7.04
wgs
Post by wgs » Tue Dec 06, 2005 12:57 am
I am having a problem compiling and installing the DCLIW70TeeChartPro7_70.dpk package. I can compile IW70TeeChartPro7_70.dpk. When I try and compile the next package, I get the following error. What am I missing here?
[Fatal Error] DCLIW70TeeChartPro7_70.dpk(32): Required package 'tee' not found
Post by Narcís » Wed Dec 07, 2005 9:21 am
Hi wgs,
It seems that that "tee" packages is not found. You should search for tee.dcu on your hard drive and add its path to the package you are compiling search path list at Project -> Options -> Directories/Conditionals -> Search Path.
wgs
Post by wgs » Wed Dec 07, 2005 4:05 pm
narcis wrote:Hi wgs,
I did that. The problem is that if I include tee.dcu then I get a conflict between tee.dcu and tee77.dcu
Post by Narcís » Mon Dec 12, 2005 11:26 am
Hi wgs,
This may be because your IDE is still referencing old TeeChart packages. You should remove/backup them and only leave v7 ones. You should also change your project references to v7 packages if necessary.
wgs
Post by wgs » Mon Dec 12, 2005 3:17 pm
Is there a list somewhere of all the TeeChart files that need to be removed?
Post by Pep » Sat Dec 17, 2005 8:11 pm
are you using the sources availables on our web site at :
http://www.steema.com/products/teechart ... Delphi.zip
If so, you should change the requires section by tee77, instead of tee, because you're using the TeeChart Pro 7 for Delphi7.
