Swaping values and series in bar-chart
Normand Peladeau
Post by Normand Peladeau » Mon Oct 03, 2005 1:38 pm
Yes! It work fine! But why can't I get this simple application to work even when compiling on a newly installed D7 on a new computer?
narcis wrote:Hi Normand,
Did you test the .exe I posted?
Post by Narcís » Tue Oct 04, 2005 8:18 am
Hi Normand,
This may be a problem we have found on some ocasions. You could try changing the following line:
  for I := 1 to NbOldSeries do BarChart.RemoveSeries(BarChart.Series[0]);
for this one:
  for I := 1 to NbOldSeries do BarChart.Series[0].Free;
Normand Peladeau
Post by Normand Peladeau » Tue Oct 04, 2005 8:14 pm
Great! It works! I will make sure the RemoveSeries is never used unless I see a note that it had been fixed.
Thanks!
Post by Narcís » Wed Oct 05, 2005 7:51 am
Hi Normand,
I wouldn't take that as a habbit as it doesn't happen on all ocasions. However, I'm glad to hear we finally found a solution for your problem.
Normand Peladeau
Post by Normand Peladeau » Wed Oct 05, 2005 10:11 pm
I thought the two were functionnally equivalent, but you seems to suggest that they are not. Can you tell me the differences. Will using the .free method causes some memory leaks or some settings not to be set properly?
Post by Pep » Thu Oct 06, 2005 8:09 am
Hi Normand,
The RemoveSeries method deletes (but not destroys) the specified ASeries parameter from the Chart list of series.
Calling this method is exactly the same as doing:
ASeries.ParentChart := nil ;
The Free method frees the Serie of Class SeriesClass.
