Error message : Identifier not found "vkSpace"
Posted: Thu Jun 26, 2025 2:37 pm
by 114100516
I tried to download and install TeeGrid-Registered-1.18.exe.
But I get an error that "vkSpace" cannot be found.
Please tell me how to fix it.
I'm using Lazarus 4.0
Thank you for your kindness.
Re: Error message : Identifier not found "vkSpace"
Posted: Thu Jun 26, 2025 3:42 pm
I've just sent you mail with the link to download the same zip I prepared for
another customer, which contains a fix for that error, and the password to extract it.
Posted: Fri Jun 27, 2025 10:59 am
by 114100516
I received the file you sent and completed the package installation. Thank you for your help.
However, the program crashes while editing the Columns title using the Editor. I tested it using Lazarus 4.0, I'll test it a bit more and ask again if it's still a problem.
Posted: Mon Jun 30, 2025 7:57 am
Pegasus wrote: ↑Fri Jun 27, 2025 10:59 am
I've been playing with the Colums Title without observing any crash.
- mstsc_pA0Mn1MckD.png (98.08 KiB) Viewed 39217 times
Could you please detail what should I do to reproduce the problem?
Posted: Wed Jul 09, 2025 11:25 am
by 114100516
Most of the time it works fine. But sometimes when I input Header text (in Korean) and click somewhere else like ListBox (when Memo Box where Header text is input loses focus), Lazarus freezes.
This happens sometimes. So it's hard to explain the specific situation where it happens.
Posted: Fri Jul 18, 2025 7:56 am
I've been adding and removing columns without any freezing so far.
- lazarus_korean.png (122.02 KiB) Viewed 17849 times
If you find a solid way to reproduce the problem, please don't hesitate to let us know.
