TeeGrid 1.1, Lazarus 2.2.0 and Linux Installation
Posted: Thu Mar 24, 2022 10:41 pm
Installation of TeeGrid 1.11 Fails on Ubuntu Linux with Lazarus 2.2.0.
System: Linux dev-1 5.13.0-30-generic #33~20.04.1-Ubuntu SMP Mon Feb 7 14:25:10 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Lazarus version: 2.2.0 Feb 01 2022
FPC version: 3.2.2
Installed on to windows machine to get source (really need an archive dist for linux). Moved source to linux box into directory with no spaces in name and tried to install using "Package | Open Package File *.lpk " and selected Sources/Packages/teegrid.lpk
From Package Dialog select Use|Install , compile IDE. and gets error:
Compile package teegrid 9.0: Exit code 1, Errors: 1
VCLTee.Editor.Scrolling.pas(13,13) Fatal: Cannot find windows used by VCLTee.Editor.Scrolling.
Not sure what's up with the different version number in the message above.
Ctrl-Click on Windows unit in uses clause opens windows in editor.
Exact same steps with Lazarus 2.2.0/FPC 3.2.2 on Windows 10 works using same steps. Does not work with automatic installer.
Could use some assistance on this as product has to run on linux.
FPC version: 3.2.2
