Page 1 of 2
TeeGrid - Delphi 11
Posted: Wed Sep 15, 2021 4:31 am
by 18680139
Delphi 11 has just been released. Whether TeeGrid will be supported it ?
Re: TeeGrid - Delphi 11
Posted: Thu Sep 16, 2021 11:26 am
We are working on new installers for TeeGrid to support RAD 11.
Posted: Thu Sep 16, 2021 1:41 pm
by Marc
Greetings,
The new installer for RAD Studio 11 is now available for download.
See:
https://www.steema.com/version_info/gridvcl/last for information.
Download available via the customer page:
https://www.steema.com/login
Posted: Fri Oct 29, 2021 7:10 am
by 18680139
I have installed the Teegrid 1.11 into Delphi 11 but the compiler is showing FMXTee.control not found.
Please help
Posted: Fri Oct 29, 2021 9:16 am
by 18680139
The compiler is showing FMXTee.Control and FMXTee.Grid not found in building Linux 64 application. Under Windows Apps is no problem.
Posted: Fri Nov 05, 2021 7:55 am
I see TeeGridRecompile builds TeeGrid 1.11 for linux platform in RAD 11 without errors:
- TeeGridRecompile_RAD11.png (52.27 KiB) Viewed 67453 times
But the "Compiled\Delphi28.linux64\Lib" folder doesn't contain any "FMXTee.*" unit. We'll revise it.
In the meanwhile, I've checked adding the "Sources" and "Sources\FMX" folders to the "Library path" for "Linux 64-bit" platform works fine.
Posted: Thu Nov 11, 2021 4:36 am
by 18680139
I have noted your reply but how to resolve it ?
On the other hand, I have tried to download the teegrid binary 1.11 from the official web site but the downloaded binary is only 2K file instead of 1392MB as stated in the web site.
Posted: Thu Nov 11, 2021 7:50 am
laiyukwa wrote: ↑Thu Nov 11, 2021 4:36 am
As I mentioned above, you could add the "Sources" and "Sources\FMX" folders to the "Library path" for "Linux 64-bit" platform. Have you tried it?
I've just downloaded TeeGrid-Binary-1.11.exe and it's 13,9MB. Could you please try it again?
Where have you seen it's 1392MB?
Posted: Fri Nov 12, 2021 3:23 am
by 18680139
Sorry, the web site is showing 13,92MB but the downloaded binary is only 2kb even I use the browser of Firefox and Safari in Mac Computer as the same result of in windows platform. Such download file is only 2kb.
Posted: Fri Nov 12, 2021 9:16 am
The public link to TeeGrid Binary v1.11 is here:
https://www.steema.com/files/teegrid/in ... y-1.11.exe
Posted: Sat Nov 13, 2021 4:11 am
by 18680139
Thank you for your help
Posted: Thu Dec 16, 2021 4:22 am
by 18680139
Yeray wrote: ↑Fri Nov 05, 2021 7:55 am
I have just had the time to build Linux-64 bit according to your indication. However, this method cannot be worked. It is the same result "Compiled\Delphi28.linux64\lib" folder doesn't contain any "FMXTee.*" unit.
Please help again.
Posted: Wed Dec 22, 2021 8:48 am
Have you tried adding the "Sources" and "Sources\FMX" folders to the "Library path" for "Linux 64-bit" platform?
Posted: Thu Dec 23, 2021 6:34 am
by 18680139
Have already adding to "Ordered list of Library paths" of Linux 64-bit platform. But no help.
Posted: Thu Dec 23, 2021 7:32 am
What error are you getting?
