Calculation of totals (incorrect examples)
Posted: Fri Oct 05, 2018 9:02 am
by 18683216
Delphi version: Seattle (Not tested in Tokyo)
TTeeGrid version: VCL & FMX Registered version-1.06
Multidevice Application (FMX)
Platform: WIN32
The examples contained in Tee.Grid.Totals are not compilable, they seem developed for older versions of TTeeGrid.
In both examples the compiler gives the following error [dcc32 Error] : E2034 Too many actual parameters
With the examples of www.steema.com/product/gridvcl the same thing happens.
This would be an example if it works correctly for me.
    uses Tee.Grid.Totals, Tee.Grid.Data
    TeeGrid1.Totals := TColumnTotals.Create( TeeGrid1.Footer );
    TeeGrid1.Totals.Calculation.Add( TeeGrid1.Columns['kilograms'] , TColumnCalculation.Sum );
Greetings and thanks.
Re: Calculation of totals (incorrect examples)
Posted: Thu Oct 11, 2018 8:50 am
by Marc
Thanks for the problem report.
At the moment this is what I see as working correctly, see https://github.com/Steema/TeeGrid/blob/ ... _Array.pas
// Setup grid Footer bands
var tmp : TColumnTotals;
TeeGrid1.Footer.Clear;
tmp:=Totals(TeeGrid1.Footer);
calls:
// Return a new Totals grid-band
function Totals(const ACollection:TCollection):TColumnTotals;
  result:=TColumnTotals.Create(ACollection);
  result.Calculation.Add('Name',TColumnCalculation.Count);
  result.Calculation.Add('Children',TColumnCalculation.Sum);
  result.Calculation.Add('Height',TColumnCalculation.Average);
  result.Calculation.Add(result.Columns['Address'].Items['Number'],TColumnCalculation.Max);
  result.Format.Font.Style:=[fsBold];
The syntax/overload you referenced also works ok in this demo.
ie.
or in this case for example:
  tmp:=TColumnTotals.Create(TeeGrid1.Footer);
  tmp.Calculation.Add(TeeGrid1.Columns['Children'],TColumnCalculation.Sum);
The key to the difference seems to be the use of "tmp as TColumnTotals", rather than calling "TeeGrid1.Totals" (unfound by the compiler). I'll look around for examples; that may be old syntax as you suggest or simply an error where we have it included in documentation. We'll change examples we find for the new syntax.
