Unable find mouse click event on rectangle
Posted: Fri Sep 08, 2023 11:56 am
by 17795639
I have been trying to find the click event on the rectangle, how can I detect the rectangle by click event?
Re: Unable find mouse click event on rectangle
Posted: Fri Sep 08, 2023 12:07 pm
I'm not sure how are you exactly drawing those rectangles, but here's an example of detecting a mouse click on a drawn ellipse.
Posted: Mon Sep 11, 2023 1:37 pm
by 17795639
I am using the below
formatBlue: Tee.IFormat;
this.Chart.ondraw = function () {
  for (let i = 0; i < this.data.length; i++) {
    let x1 = this.axes.bottom.calc(startDate);
    let x2 = this.axes.bottom.calc(data[i]);
    let y1 = this.axes.left.startPos;
    let y2 = this.axes.left.endPos;
    this.formatBlue.rectangle(x1, y1, x2 - x1, y2 - y1);
I need every click event for every formatBlue will draw .
Posted: Tue Sep 12, 2023 7:43 am
In that case you should do something like this in your event listener:
const body = document.body;
body.addEventListener('click', function(evt) {
  for (let i = 0; i < this.data.length-1; i++) {
    const x1 = this.axes.bottom.calc(this.data[i]);
    const x2 = this.axes.bottom.calc(this.data[i+1]);
    const y1 = this.axes.left.startPos;
    const y2 = this.axes.left.endPos;
    const rect = new Tee.Rectangle(x1, y1, x2 - x1, y2 - y1);
    const p = {
      x: evt.x,
      y: evt.y
    if (rect.contains(p)) {
      console.log(`in rect ${i}`);
Here a working example.
Posted: Tue Sep 12, 2023 11:36 am
by 17795639
Click event working in angular but event.x & event.y are not match with data
    this.clickObservable$ = fromEvent(document.body, "dblclick");
    this.clickSubscription$ = this.clickObservable$.subscribe((evt) => {
    this.onDobuleClick(evt);
    // double click events
    onDobuleClick(event: any) {
    for (let i = 0; i < this.TChart.Data.length; i++) {
      const subActivity = this.TChart.Data[i].SubActivity;
      const startDate = new Date(this.TChart.Data[i].StartDate);
      const endDate = new Date(this.TChart.Data[i].EndDate);
      let x1 = this.TChart.axes.bottom.calc(startDate);
      let x2 = this.TChart.axes.bottom.calc(endDate);
      let y1 = this.TChart.axes.left.startPos;
      let y2 = this.TChart.axes.left.endPos;
      const p = {
        x: event.x,
        y: event.y,
      console.log(this.TChart.Data[i]);
             break;
Posted: Thu Sep 14, 2023 10:42 am
by Marc
Using TeeChart's own mouse events, here ES6 coded, you can try:
import { Chart, Line, Format, Rectangle } from '../../src/teechart.js'
drawChart();
function drawChart(){
	const msecsInADay = 86400000; //24*60*60*1000
	const now = new Date();
	const data = [];
	for (let t = 0; t < 10; t++) {
		const p = {
		x: new Date(now.getTime() + t * msecsInADay),
		y: Math.random()*100,
		color: "rgb("+Math.random()*255+","+Math.random()*255+","+Math.random()*255+")"
	  data.push(p);
	const chart1 = new Chart("canvas1");
	chart1.legend.visible = false;
	const series1 = chart1.addSeries(new Line());
	series1.format.stroke.size = 4;
	chart1.zoom.enabled = false;
	/*series1.onclick=function(series,index,x,y) {
	  alert("Clicked point: "+index);
	series1.data.x = new Array(data.length);
	for (let t = 0; t < data.length; t++) {
	  series1.data.x[t] = data[t].x;
	  series1.data.values[t] = data[t].y;
	const myFormat = new Format(chart1);
	myFormat.gradient.visible = true;
	myFormat.gradient.colors = ["white", "lime"];
	myFormat.transparency = 0.3;
	chart1.ondraw = function() {
	  for (let i = 0; i < data.length-1; i++) {
		const x1 = chart1.axes.bottom.calc(data[i].x);
		const x2 = chart1.axes.bottom.calc(data[i+1].x);
		const y1 = chart1.axes.left.startPos;
		const y2 = chart1.axes.left.endPos;
		myFormat.gradient.colors[1] = data[i].color;
		myFormat.rectangle(x1, y1, x2 - x1, y2 - y1);
	chart1.mousedown=function(event) {
		const rect = new Rectangle(x1, y1, x2 - x1, y2 - y1);
		const p = {
		  x: event.x,
		  y: event.y
				//alert("in rect: " + i);
	chart1.draw();
See: https://www.steema.com/files/public/tee ... s_ES6.html and open the console in your browser.
Posted: Thu Sep 21, 2023 10:41 am
by 17795639
Sir,
It's not matching with mouse pointers, I double-checked that the X and Y coordinates are always the same with various screen sizes but it's not working. Any help ?
here is the my resize code
  resize() {
    var body = document.body;
    let _canvas: any = this.TChart.canvas;
    const topMargin = 200;
    var width = 80,
      height = 70; // <--- % PERCENT
    _canvas.width = (width * body.clientWidth) / 100;
    _canvas.height = (height * body.clientHeight - topMargin) / 100;
    this.TChart.bounds.width = _canvas.width;
    this.TChart.bounds.height = _canvas.height;
    this.TChart.draw();
Posted: Tue Sep 26, 2023 10:20 am
by Marc
Hello
Here's the approach used in the Steema demos:
https://www.steema.com/files/public/tee ... est/demos/
This one for example, https://www.steema.com/files/public/tee ... ghlow.html, the resize routine is in demo.js. It modifies the width but could apply the technique to height.
(https://www.steema.com/files/public/tee ... os/demo.js)
  static resize(element) {
    if (element != null) {
      let w = 0
      let xContent
      let canvas
      let chart
      if (element instanceof HTMLCanvasElement) {
        canvas = element
        if (canvas.chart instanceof Chart) {
          chart = canvas.chart
          xContent = $(canvas).closest('.x_content')[0]
          w = parseFloat(window.getComputedStyle(xContent, null).width) | w
          canvas.width = w
          chart.bounds.width = w
          chart.draw()
..or this approach being used here: https://www.steema.net/TeeChartBlazor/chartpanel/101
function resize(element) {
        var w = 0, xContent, canvas, chart;
            canvas = element;
            if (canvas.chart instanceof Tee.Chart) {
                chart = canvas.chart;
                hostChart = canvas.chart;
                if (element.offsetParent != null)
                    w = element.offsetParent.clientWidth - 280;
                else {
                    xContent = $(canvas).closest('.tabcontent')[0];
                    w = xContent.parentElement.offsetWidth * 0.95;
                canvas.width = w;
                chart.bounds.width = w - 30;
                chart.draw();
function resizeC(chart) {
    resize(chart.ctx.canvas);
Posted: Tue Sep 26, 2023 1:56 pm
by 17795639
Resize was working well, but I couldn't get the right coordinates for mousedown. And its working for mousemove
Posted: Mon Oct 02, 2023 4:09 am
by 17795639
In my case, it was working with event.clientX isntead of event.x :D :D :D :D
