How to change CursorTool position(both x and y-axis) onClick
Posted: Tue Jul 10, 2018 4:19 am
by 14047022
I'm using ColorGrid for chart creation and i want to change CursorTool position(x-axis and y-axis coordinates) based on click. Can any one help us to achieve this. And is there any way that we can give position values for x-axis and y-axis so the cursortool can be re-arranged to that position. If any one has done already please give us solution.
Re: How to change CursorTool position(both x and y-axis) onClick
Posted: Fri Jul 13, 2018 8:55 am
You can call the CursortTool mousemove function at the Chart's mousedown event as follows:
var t = new Tee.CursorTool(Chart1);
t.format.stroke.size=2;
t.format.stroke.fill="#BB0000";
t.render="layer";
t.followMouse=false;
Chart1.tools.add(t);
Chart1.mousedown=function(event) {
t.oldFollowMouse = t.followMouse;
t.followMouse = true;
var p = new Tee.Point(0, 0);
t.chart.calcMouse(event, p);
t.mousemove(p);
t.followMouse = t.oldFollowMouse;
Posted: Wed Jul 18, 2018 10:50 am
by 14047022
Thank you so much for your reply, it is working fine, only if we add "t.dragging = 0", otherwise it is not working. and how to set x-axis value to zero when chart is loading first time or how to change positions of x and y manually(might be the scenario is another buttons and i want to change x or y position by increment one by one).
Yeray wrote:Hello,
t.render="layer";
t.mousemove(p);
Posted: Fri Jul 20, 2018 9:43 am
You can manually set a position knowing the pixel coordinates, or calculating them from the axis values. To do this, instead of this:
Do this:
var p = new Tee.Point(Chart1.axes.bottom.calc(80), Chart1.axes.left.calc(80));
Posted: Tue Jul 24, 2018 4:16 am
by 14047022
Thanks, it is working fine now.
